Question about Maytag Neptune MAH7500WH Front Load Washer
Door will not lock to start wash cycl
I have a MAH7500AWW which worked without any problem for 7 years. I have the whole door assembly replaced recently because the machine kept giving a message, " The door did not appear to lock..." After a few repeated door closings and pressing "off" & "start", I managed to start the cycle. It would work well for a few cycles and stop again. When the door lock is energized and closed, the wash cycle would complete without a hitch. Any help will be greatly appreciated -- short of changing the main machine control board. I checked all possible loose connections. I tested for continuity for the door lock switch: P8(3) and the neutral and P1(1) and the neutral prong of the power cord. Instead of a constant buzzing sound of the voltmeter that I expected, both tests showed a reading.
Posted by kgoh on
  • 16 more comments
  • kgoh Nov 28, 2007
    Mike,
    Thanks for the reply. I only changed the assembly, not the door. Having gotten a new one, I tested and compared the characteristics of the old with the new one; I really didn't find any difference.
    The latch works intermittently, both for the new and old. The reading across P3-8 and P3-3 is 46.2 volt in an unlocked position, zero when locked. The door solenoid is ~62 ohms relative to the common, ~120 ohms lead-to-lead. Tested both the "Door Close" and door switches; both worked.
    When tried to start a cycle, the machine would return an error message that the door did not lock. I then toggled the solenoid lever to latch and unlatch the door, repeating the "off" then "start" cycles, the machine would magically start with one of these trials (the lid of my machine was up, but the door hinges were fastened without the front cover).
    When I ran the diagnostics, I got code 47 all the time. When I cycle-tested it, the test would complete without a hitch if the machine were able to close the door latch. Otherwise, all functions would complete, except for the spin.
    Once the cycle starts, the wash would complete perfectly. Loose connections?
    I will attempt to follow the solenoid circuit segment by segment next. Any suggestion for a short-cut.
    Many thanks,
    Kim
  • kgoh Nov 28, 2007
    Mike,
    Your last message reinforced my hunch that I might have a loose
    connection somewhere in the circuit. I decided to unplug every connection in
    the machine and re-seated them making sure that every contact point was
    affected. It worked!! I tested with 20 odd start/stop cycles,
    disconnecting and reconnecting the plug to the wall outlet. I stopped the testing before I break
    something else. The machine still works!
    Many thanks,
    Kim
  • Anonymous Mar 11, 2014
    no message tone alert
    how can I manually close the trunk on a 2007 lincoln towncar
    what is e2 code
    recently my truck cut off and will not start back up, the next day I went out to check my truck and it started for about 2-3minutes and then it shut off again when I turn the ignition on it sounds like it wants to start but it will not can it be my fuel pump relay.
    I accidentally changed the language on my 2013 Ford F150 to another lanugage. I want to change it back to english.
    I am searching for my January- February exam results for 2014
    h1 error
    Need to replace door
    door bell not ringing on avaya phone system
    hp 4350 doesn't pickup paper from drawer 2
    I have used this 32GB flash drive maybe 15 or 20 times with no problem on my laptops at work and at home. Two days ago it quit showing up under computer and I can't access it. When plugged in the computer makes a noise like it is recognizing it, but there is no "loading driver" msg, only the tone. The last two times I used it on my main laptop I had turned on the readyboost function, would that have caused some sort of problem? Anyway, it doesn't work now on any computer, just get the tone and no way to save to it or view its contents. Is there a way to salvage it? Can't seem to find another driver, my computer device manager seems to think the generic driver is up to date, and doesn't recognize the drive so probably isn't looking for a pny specific driver. Thanks, any help would be appreciated.
    My freezer has ice build up and leaks water. I do not have an ice or water dispenser. Can not find the drain to see if it is plugged.
    Won't play CDs in cd changer wat am I doing wrong 2001 mercedes c220.
    what is the bolt sequence when putting intake manifold back together on a 2001 ford windstar
    Fog light replace
  • Anonymous Mar 12, 2014
    my Panasonic cordless phones are not working. I get the message "no link to base" what does that mean?
Anonymous
  • 290 Answers
This sounds like a classic door lock problem. There was a design change in the lock assembly because of numerous problems.
You say you had the door replaced, did they replace the lock assy also?
The control puts power to the wax motor that operates the latch. As the door locks, the latch activates the lock switch that tells the control the door is locked.
What kind of reading are you getting on the lock switch?
Thanks/Mike
Posted on Nov 25, 2007
  • 1 more comment
  • Anonymous Nov 25, 2007
    According to the diagram I have,
    You should have continuity through the door lock switch when the door is locked on P3-8 gray wire to P3-3 blue wire.
  • Anonymous Nov 28, 2007
    It sounds like you have a control problem.
    The problem with diagnosing it is it being erratic. I would rather something break and stay broke. It makes it a lot easier to find the problem.
    If you are losing the signal voltage across p3-8 and p3-3 when the latch closes, then the door lock switch should be working properly. If it still gives the door lock message when you can tell that the switch is closed with your meter, then the board is not sensing the voltage. You probably have a loose solder joint somewhere in the board and will have to replace the control.
    Go through the checks you have in your tech sheet and see what you find out.
    When the control locks the door, it puts 120VAC to the lock solenoid from P1-1. It sends 24VDC to the door lock switch from P3-3 and it returns to the board through P3-8. This signal voltage tells the board the door is locked.
    If you have these readings and the door is locked but you still get the door lock code then the problem must be in the control.
    Thanks/Mike
    Great! Glad to be of some small help.
    Thanks/Mike
GE front load washer model WCVH6260HWW unlock light stays on, machine won't run
Possibly need a new latch assembly per the suggestions at the link below:
https://www.repairclinic.com/PartDetail/Door-Lock/WH10X10006/1168668
https://www.justanswer.com/appliance/38tio-front-load-washer-reads-door-locked-model-xxxxx-when.html
Question asked many years ago:
3/11/2010
Appliance Technician: Tyler Z.
You will need to remove the lower front panel. There are 3 screws along the bottom. Remove these screws and remove the panel. Next, pull the plastic pull tab on the bottom of the latch assembly to manually unlock the door latch and then shut the door. Then start a cycle and cycle it to see if it will unlock on it's own. If not then you need to replace yoru door latch assembly. Here is a link to the part.
CLICK HERE
Tyler Z., Appliance Doc
Category: Appliance
Satisfied Customers: 87,538
Experience: 9+ years being an appliance technician with factory training.
We tried this and it did not release...is there anything else we can do?
not really unfortunately, you can try holding the door switch button in and try to start and cycle a cycle but I'm not sure that will work either, it sounds like you might just need a new latch assembly.
Does the latch have an actuater that would buzz or make a weird noise during a cycle?
not really no.
Front Load washer reads door locked model wcvh6260hww when
Jun 09, 2018 | GE Washing Machines
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
The washing machine works fine the only thing is that the spin doesn't work, it starts but never gets to it's optimal speed. Clothes are soaking wet when the cycle ends. Our washing machine is a...
Hi
The issue is with the door lock assembly that is bad and should be replaced. If the door lock assembly is bad the control will sense that the door is open and so will not start a spin cycle. If you want you can test the door lock assembly with a voltmeter before replacing it. Hope this helps...please post back for further assistance.
Daniel
May 09, 2011 | EuroTech EWF150 Front Load Washer
Everything works but it does not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue. Click on the link below for the complete and detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Dec 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a frigidaire affinity front loader washer that the final spin cycle won't work on. The rest of the wash cycle is fine and the basket spins for the other cycles just not the spin cycle. It is also...
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Jul 13, 2010 | Frigidaire ATF6000ES Front Load Washer
I cannot open the door after the finish of the
Hi There
I have found this for you to read.let me how it goes. Hope this was helpful.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Washing Machines
Get DL ...F ERROR CODE
hi,
Error dl f --
Condition:
Door Lock Error-
Check/Repair:
1. Door Lock Mechanism broken or removed from the Door.
2. Check Door Lock/Switch Assembly.
3. Check the wire harness connections to the Door. Lock/Switch Assembly and Central Control Unit (CCU).
4.Door Lock/Switch Assembly Failure.
good luck....
Mar 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Nexxt Essence Washer
start a cycle, once the door lock light comes on pull on the door to see if its really locked if not, you need a new door lock assembly
Nov 12, 2007 | Bosch WFMC2100UC Nexxt Essence Washer
Door Lock LED flashing
Hello, This depends on how old your machine is mine is now 7 years old so I do not want to invest in long term soltions. So I repaired my own, I bought a new interlock and replaced the old one that did not work. So I shorted out the three links that go to the interlock, the machine now shows the lock is always on and you can open the door during the wash cycle so BEWARE. Also if you have never wired a plug or fixed basic electrics DO NOT DO THIS. 1. Turn off power and unplug. (Very Important) 2. Remove lid you will need torx drivers. 3. Unscrew door interlock from the front of the machine. 4. Lift out interlock. Try replacing the interlock with spare first (about £15). 5. If new interlock does not work do the following. 6. Put Interlock back on without wires attched to it. 7. From car spares shop buy spade conectors and create a three way shorting link (insulate well). 8. Put shorting link into each of the wires that go to interlock. Safely tie up wire to a loom (do not let dangle) 9. Shut the door remove hands and try starting the machine. 10. If that works put the machine back together. And warn people that the DOOR CAN BE OPENED DURING WASH CYCLE and STARTED WITH DOOR OPEN. So check when the machine has stopped properly.
Oct 20, 2006 | Hotpoint WMA58 Front Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
557 people viewed this question
Top Maytag Washing Machines Experts
John Tripp
John Tripp
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
