Question about Whirlpool Home
How to clean jet on whirlpool tub
Vinegar or 4 parts water 1 part muriatic acid
Posted by Pam Pagel on
5 Related Answers
brainyass
Brainyass Rabbit
  • 242 Answers
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Posted on Oct 24, 2008
Anonymous
  • 14 Answers
SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
Posted on Dec 27, 2008
Anonymous
  • 125 Answers
SOURCE: my whirlpool bath tub has three jets that work & 3 jets that are
The suction IS the water intake. it takes the water from the tub into the pump and the water comes back out through the jets.
Posted on Feb 24, 2009
snap101
snap101
  • 117 Answers
SOURCE: can you cap off the jets of a whirlpool tub if you
you can but it's not worth the trouble of doing it! lots of fiberglass and you need to have access to the whole tub on the sides
Posted on Jul 29, 2009
Alan
  • 80 Answers
SOURCE: cleaning a whirlpool tub
The jets turn yellow from exposure to the sun, not much you can do except replace the jets (costly). What is leaking? if you broke the seal on a jet it will leak and have to be resealed.
Posted on Aug 20, 2009
CLEANED SYSTEM WITH VINIGAR,SERVICE LIGHT STILL COMES ON
Theres usually a reset button after you do cleaning for salt chlorinators, reset that.
  • Otherwise if you can see any calcium still clean it again with vinegar possible longer times or multiple times, its a mild calcium remover.
  • You can use muriatic acid mixed with 4 parts water to remove everything, but dont let it touch any metal, just make sure to take proper precautions with it, and read/follow labels.
Aug 25, 2015 | Pool & Spa
My salt water pump wont make chlorine
make sure the chemicals are balanced then make sure your salinity is correct clean sensor and cell in a 4 to 1 mixture of water 4 parts and muriatic acid should work then
Sep 27, 2014 | Pool & Spa
What does the service light on the intex salt generator mean ? and what do i do?
if salt is ok check sensor clean with 4 to 1 muriatic acid 1 part 4 parts water
Sep 06, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Filter is green and clogged
make sure to soak filters in TSP tri sodium phosphate can purchase at hardware store put a handful in bucket then fill with water soak filter for 30 minutes then rinse off then soak in a 4 to 1 muriatic acid and water 4 parts water 1 part muriatic acid solution then rinse filters should be like new
Jul 22, 2014 | Aqua Vac Tiger Shark
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
I need to acid wash my grids. What is the ratio for acid and water?
Why not try white vinegar and water first, 50/50 mix. White vinegar is a mild acid, and it is a lot safer to use than acid. If you are going to use Muriatic acid ( "mild" version of Hydrochloric acid), then a good ratio is 1 part acid to 20 parts water. And Always add the acid to the water. You could make a stronger solution, 1part acid to 10 parts water, if needed. But be cautious with any ratio. Follow container directions. Wear eye protection ( an absolute must). Wear gloves, etc. This is dangerous stuff, and you can buy it at Home Depot or Lowes!
Aug 25, 2009 | Pentair FILTER TANK BOTTOM, 48 SQFT
Home Logo
54 people viewed this question
Top Whirlpool Home Experts
john h
Mike
Andrew Taylor
Andrew Taylor
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
