SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
SOURCE: Trying to hook 12 volt lights to a 36 volt golf
The exact answer depends on what battery voltage you have but this hint will get you going.
Assuming you have 3 12v batteries, just wire to the first battery + - and you'll have 12 v. If you have 6 6v batteries, wire to the first + and the second -. If you have a voltage meter, you can verify the voltage of my suggestion.
This will work for lights and other resistance circuits but not for sensitive items like radios.
Golf cart batteries are series wired to get the higher voltage.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
SOURCE: how to wire a 12volt lights to a 36 volt system on
all you have to do is run the positive wire from the lights to the positive post of one battery and the negative wire to the negative post of the same battery. You will be using just one battery to power your lights. Hope this helps
SOURCE: 36 volt ezgo
First of all, lift rear axle off the ground and place blocks or jack stands underneath. Check to see if you have 36 volts On your batteries. Now you want to run a jumper across the big cables on the solenoid. Press the accelerator and the motor should engage. Clicking is a pretty sure sign that the solenoid is bad. Please let me know if this is useful. I can further elaborate more troubleshooting if this doesn't solve your problem.
