Question about Golf
How to connect batteries on a parmaker golf cart series or parallel?
Posted by Mario Barravecchio on
ray gallant
    Top Expert:
  • 68,617 Answers
Suspect they are parallel to provide longer run life
series will make shorter life but more power
Posted on Jul 05, 2018
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
Posted on Nov 27, 2008
Anonymous
  • 76 Answers
SOURCE: We are searching for a schematic for a Legend electric golf cart
THE BATTERIES ARE RUN IN SERIES THAT MEANS THAT THE WIRES GO POS. TO NEG. NEG. TO POS. STARTING IN THE BACK AND THEY RUN LIKE THIS TILL YOU GET TO THE OUTPUT FROM BATTERIES TO MOTORS THE CURRENT GOES IN ONE SIDE OF BATTERY AND OUT THE OTHER BY CONECTING ALL POSITIVES YOU MAY HAVE JUST KILLED THE BATTERIES
Posted on Jun 25, 2009
Joe Hogan
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
Joe H.
  • 330 Answers
SOURCE: electric golf cart won't go forward nor backwards.
check key switch, and fuses.set brake before putting it in gear.The relay diods that controll power may have a wire off.
Posted on Apr 21, 2010
Anonymous
  • 957 Answers
SOURCE: How do I connect a 36V Analog Battery Charge
The indicator has a very low draw so you can put it anywhere. It would be best to wire it into the ignition switch. Power to it will not say on and will only come on when the switch is turned on.
Posted on Jun 08, 2010
My golf cart has six, 6 volt batteries connected in a chain, positive to negative throughout. Can I connect an auxiliary light of some type to this power source?
the cart is wired for 36 volts operation so you would need a 36 volt bulb
or
you could put the wiring for a 12 volt bub across the terminals of 2 batteries so the negative wire will be on a negative terminal of the first battery and a fused positive wire will be on the positive of the second battery
the batteries are connected in series so the sum total of the voltage is the sum of all of the batteries
by selecting 2 batteries in series you are using the sum voltage of 2 batteries
Nov 24, 2017 | Golf
How can i get more torque out of my cart . it is a 1996 txt series 36 volt cart
repair the motors , fit bigger power cables
clean all wires connections
use better quality batteries
Nov 11, 2017 | Golf
Need help putting new batteries in 1980 club car can't figure out how to connect wiring to new batteries
https://www.golfcarcatalog.com/golf-cart-blog/golf-cart-battery-bank-wiring-in-series/
This should solve your problem.
Next time you want to take something apart, be sure to take a picture or 2, before you disconnect anything. That will help you put it back like it was.
Jun 16, 2017 | Cars & Trucks
Old club car battery wireing digram
How old? The two most common wiring of the batteries are: (old) two batt on driver side , front one neg toward middle of cart, back one positive toward middle. Middle batteries-- both positive towards front of cart. Passenger side-- two batteries- front one - positive toward middle, back one negative toward middle of cart. Connect main negative to drivers side and main positive to passenger side- rest of them are connected in series( neg to pos to neg). The newer wiring only has two batteries that are switched- The main positive and the main negative batteries are reversed but the main cables are connected differently, you can tell by looking at what posts are not connected after wiring them in series. They will be the back ones on each side.
May 22, 2017 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Why does my golf cart battery charger turn off after 6 seconds when battery is partially discharged?
I have seen a charger turn off like that when there is one or more bad batteries. Try a load test on each battery to see if one is bad.
You can do this with a voltmeter. Connect the voltmeter to one battery and make the cart start to move and watch the meter.
If the voltage drops a lot then it could be defective.
Aug 30, 2015 | Golf
Why don't I get power to the motor on my Golf cart and how can I fix it.
Pleasecontact golf cart Kings out of Austin Texas. They will be more than glad to help you with this problem that you are encountering. Their Tek savvy is always free. Please be patient as so many people are always asking questions. But you can't beat free. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Aug 21, 2014 | RHOX Yamaha G14, G16, G19 Golf Cart 6"...
After installing six new 6V batteries in series on my 1999 Yamaha G16E golf cart, full power is fine up to the selenoid. nopower to the shifter or motor after that. Upon plugging in my charger to the cart,...
Verify series battery wiring. The main positive wire which goes to the solenoid should be on a positive battery post, that will be your main positive. Then from there we go series to all the rest of the batteries until we are left with a negative battery post, that will be your main negative. Make sure your charger wires are connected to the mains.
Sep 11, 2017 | RHOX Yamaha G14, G16, G19 Golf Cart 6"...
BuggiesGoneWild has all types of poems. Please visit their website. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Jun 15, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Golf Logo
485 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
