Dehumidifiers Logo
R
Rosa Posted on Jul 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Haier dehumidifier HDN305 manuals. Dehumidifier stopped working . Nothing happens tried different outlets already. Is there a fuse or reset button somewhere.?
My dehumidifier has a capacity of 30 pint
Terry
Level 3:
  • Haier Master 11,377 Answers
  • Posted on Jul 04, 2018
Terry
Haier Master
Level 3:
Answers
11377
Questions
Helped
4619818
Points
152765
5 Related Answers
Anonymous
  • 1304 Answers
  • Posted on Oct 09, 2009
SOURCE: Used our new Haier 45 pint dehumidifier for a
what time of year is it,
dehumidifies are almost usless below 55 degrees
Testimonial: "Thanks!"
Anonymous
  • 614 Answers
  • Posted on Oct 29, 2009
SOURCE: I have a brand new Haier 45 pint Dehumidifier. The
Most of the time you set @55% RH. But on most Portable dehumidifiers you dont have a setting that tell you percent. Set about 1/2 way and see how much water it put out. That is about 60%. Go from there. Rus
Testimonial: "Thank you. I will give it a try."
Anonymous
  • Posted on Dec 08, 2009
SOURCE: A year ago we lost the electronics board on the
It was the 125v 12amp pfuse hidden on the bottom of the board under a bluse plastic cover,
Anonymous
  • 43501 Answers
  • Posted on May 05, 2010
SOURCE: Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Anonymous
  • 43501 Answers
  • Posted on May 18, 2010
SOURCE: Whirlpool/Gold/Energy Star-Dehumidifier model:
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Hauier dehumidifier HDN305 suddenly won't turn on. No motor goes on and no red or green lights go on either. It's properly plugged in to a functioning electrical outlet which has a functioning...
You have already checked everything I would have suggested, so the only other thing I can think of is the temperature in the room, may be affecting it. If the ambient room temperature is above 112 degrees or below 32 degrees, the unit will shut OFF and not restart, until the temperature is within that range.
If you continue to have problems starting the unit, contact Haier America Customer Support 877-377-3639.
Hope this provided some help to you.
I have two Haier HDN655E dehumidifier's. One works fine and the other wont come on. I have tried unplugging and plugged back in, hit the start button and nothing happens. Is there a reset switch or a...
Have you tested the outlet it's plugged into, to make sure it still has power? If it doesn't, check the circuit breaker panel in you home for a tripped circuit breaker. If there is one, unplug the dehumidifier, before resetting it. Then plug the dehumidifier back in. If the circuit breaker trips again, the problem is within the dehumidifier or the outlet is faulty (i.e. Loose wire, burned wire, broken outlet). If the outlet is not faulty, you should contact Haier America Parts and Repair 877-337-3639.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
I have a Haier HDN305 dehumidifier. It just sopped working and will not turn on. Can you help me?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Haier HDN305 dehumidifier does not pull moisture from air and does not collect water in bucket
heatman101
Will not come on
heatman101
1helpful
I would liket to obtain an owner's manual as I have lost mine. Model HDN305
I have spoken with the folks at Haier. They have all current manuals on line for immediate down load. If yours is "classic" (read OBSOLETE), send em a e-mail and they will send you whaat you need.
I received great customer srvice from them.
2helpful
Haier hdn305 dehumidifier does not turn on
Had the same problem with two HDN455's and took them to a local electronics repair shop. They replaced a Zener ZD2 diode for a total cost of $53 and now is working fine.
1helpful
Dehumidifier won't run
After all that testing you have diagnosed the problem. It is the main circuit board. So there is not reason to do any more test. I would just get a new control board and off you go
Haier HDN305 Dehumidifier
agaver
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks qrx1llb3 for the help!
After carefully removing the plastic covers (yes, u need to remove both, I removed first the back one then the front one by pulling up, then disconnect the cable that joins the panel on the front cover with the electronic board on the upper right area) I found the electronic board with the blown up fuse. My was under a blue plastic cover. I'll try to replace it and see what happens! thanks for the help! :)
Haier HDN305 humidifier
It's on the right side under blue plastic cover.
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
