Question about Midland Radio Communications
I want to adjust the modulation on a midland alan 48+ con you tell me which pot it is
Posted by john barnes on
5 Related Answers
Anonymous
SOURCE: Midland alan 48 plus transmit scale not moving
Sorted now, soldered a new output transistor into the board and all working.
Posted on Dec 12, 2008
Michial Gueffroy
  • 1140 Answers
SOURCE: Does anybody know the wiring sequance that you
Its not in my area of expertise but maybe this link will have some info:http://www.dxzone.com/catalog/Technical_Reference/Mic_wiring/
Posted on Sep 01, 2009
spicemaster
  • 40 Answers
SOURCE: when driving over rough ground my midland alan 48
Check for loose buttons, could be something loose inside, if its changing on its own when its moving around could be from vibration that something has come loose.
When parked just try shaking the mic first if that doesnt do it shake the cb itself and see if the problem persists
Posted on Jun 20, 2010
Don Reiman
  • 773 Answers
SOURCE: garbled modulation midland 1001z. I
the ANCE is DM1. you can adjust the.modulation by turning it. you can also just back the Mic gain down until the aaudio is cleaner.
Posted on Aug 01, 2011
How th adjust peek modulation on a midland 1001lwx cb radio
VR 2 is the pot you are looking for an now you need a modulation meter. Speak into the mic at the volume you will be talking on the radio. One one one one while adjusting for 100 percent anymore an you will begin distorting.
Jun 03, 2014 | Midland 1001LWX CB Radio
Can a midlands 48 alan be used in ireland
anything can be used anywhere until you get caught with it. I think all it needs is to be modified to Irelands standards and you should be fine.
Jun 02, 2014 | Midland Radio Communications
The awi lights on a midlands alan 48 does what
AWI stands for antenna warning indicator. now you know.
Modulation on 1001Lwx midland cb low need to know which pot to adjust
hello,
The limiter is what limits the modulation. Often times there is a pot that you can turn to adjust it. To get more power and swing out of your radio do this DM1 is the mod limiter RVM1 is the mod pot. Adjust this for maximum modulation. Spread the coils marked Lt5/LT12 just a little Spread LT7/LT11 a lot.
Regards, Tony
Apr 13, 2011 | Midland 1001Z 40-Channels Base CB Radio
Midland1000cb very littel audio w/stock or powermic,what is the limiter?
DM1 is the mod limiter RVM1 is the mod pot. Adjust this for maximum modulation Spread the coils marked Lt5/LT12 just a little Spread LT7/LT11 a lot
Hope this helps.
Mar 08, 2011 | Midland 1001Z 40-Channels Base CB Radio
Dec 11, 2008 | Midland Radio Communications
Radio Communications Logo
55 people viewed this question
Top Midland Radio Communications Experts
eradiostore
eradiostore
Michael Thomas
Michael Thomas
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
