SOURCE: Magenta Near Empty??
This is only a reminder! The cart will show "empty" when it is really empty. You can print on until the printer stopps because of empty cart (and prints on when it is replaced).
Take the new on out and put it in again. answer display question with "1" (Yes, cart changed). "Near empty" Message will disappear.
maybe u ahve virus hich showoing it full
format it or maybe u have saved alot of msgs and music
SOURCE: When I calibrate colour Magenta and Lt.Cyan fail to print
boil the head printer in a hot water for ten minutes and wiped it smoothly
SOURCE: Xerox Phaser 8500 Add Magenta Ink will not go out
it sounds like a sensor has failed in the ink cradle, to have a look you want to undo the two screws as the back on both sides then with the output flap & front cover open, you can gentley pull the plastic arround the display off, this will allow you to remove both the sides, the the ink cradle and melting units will jest lift out from the top, (make sure the printer is cold at this stage!!!!!!!!) then there are a few screws to remove then the unit will be in bits where you can test the bottom 'ink out sensor' & replace is needed.
SOURCE: The Magenta has stopped printing, but the ink tank
While changing the ink tanks there can be possible erros for the software to adjust with the new ink cartridge. So remove printer and reinstall the software, thenmake a test print , if the fault still shows up, a possible chance of the head being faulty is not ruled out.
