Question about Miele Cooktops
Best College in Bangalore - New Shores International College
Posted on Aug 30, 2021
Https://www.coolblue.nl/en/advice/errors-miele-induction-cooktops.html
How do I unlock my Miele cooktop? Just under the lock light you should be able to press/hold with your thumb for about 5-15 seconds and it should reset. You may need to place your thumb directly over the lock light or just below it and hold it for that time.
Just under the lock light you should be able to press/hold with your thumb for about 5-15 seconds and it should reset. You may need to place your thumb directly over the lock light or just below it and hold it for that time. If this doesn't unlock when you do this then you have a problem with the control board.
Posted on May 03, 2020
SOURCE: My miele induction schott ceran
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
Posted on Apr 25, 2011
SOURCE: burn fuses
Something inside is short-circuited. All components look fine thans to burned fuse. Don't try it anymore with new fuses. You need to get a repairman to check it out.
Posted on Apr 09, 2008
SOURCE: induction cook tops
good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
SOURCE: how to un lock my GE Profile Induction cook top?
Try
turning off the breaker for at least 10 min and re apply power. If this doesn't
work, then there's an internal problem.
If after 10 minutes the cooktop is STILL locked:
Push the touch
pad that looks like a padlock for at least 5 seconds. The lock light should go
out.
Posted on Nov 15, 2010
CALL CUSTOMER SERVICE WHERE YOU PURCHASED IT FROM
Posted on Jul 17, 2014
GBWhatsapp apk Download Latest Version 2018. Download Latest GB Whatsapp for Use 2 Whatsapp in One Mobile.http://appgbdownload.com
Thanks for sharing.I found a lot of interesting information here. A really good post, very thankful and hopeful that you will write many more posts like this one.Great websites!https://shareits.xyz/download-shareit-pc...
https://www.sattakingnow.in/
https://www.satta-king-result.co.in/
shareit for pc
Satta King
Satta King
