Cell Phones Logo
Antoinette Van Rooyen Posted on Jul 03, 2018
I wud like to know how to enable apn on mobicel v1
  • brandon Bernard
    brandon Bernard Oct 05, 2018
    My mobicel v1 isnt turning mobile data on... What can I do
  • ADMIN Andrew
    ADMIN Andrew Oct 06, 2018
    The settings you require for your Mobicell are as follows:
    Internet Settings for MTN
    1. Go to Menu > Services > Data Account > GPRS
    Create Profile
    Account Name: MTN GPRS
    APN: Internet
    Auth Type: Normal
    2. Go to Menu > Services > Wap Settings > Edit Profile
    Create Profile
    Homepage:http://www.mtn.co.za/wap
    Data Account: MTN GPRS
    Connection Type: HTTP
    Proxy Address: 196.011.240.251
    Proxy Port: 8080
    Username: mtn
    Password: mtn
    Please follow the link for more settingshttp://mobicell.co.za/internet-and-mms-s...
    Thank you
Sylvester
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 10, 2022
Sylvester
Contributor
Level 1:
Answers
Questions
0
Helped
1721
Points
Follow the instructions given on the link below.
http://helpkings.co.za/index.php?qa=272&qa_1=how-to-add-apn-on-an-android-device
Can't turn on data on mobicel rebel
If you can't turn on data on your Mobicel Rebel, check your phone's settings, make sure mobile data is enabled, and confirm that you have a data plan or sufficient balance with your mobile carrier. If the issue persists, contact your carrier for assistance.
Nov 04, 2023 • Cell Phones
Does a mobicel v1 switch its mobile data
I have data connection problem with my phone Mobicel v1
Mar 27, 2019 • Cell Phones
I have a verizon samsung galaxy s5 i put in a life wirless sim card in it. It works but i dont have no data, i think i need the APN settings can anyone help
On the main screen of the Galaxy S5, select Settings.
You should now be able to see Mobile Data - Access Point Names, hit there
Once you are in the APN, please delete any existing APN you have listed there, after that, please create a New APN
  • APN: wholesale
  • APN type: default,mm,supl
  • Proxy: not set
  • Port: not set
  • Username: not set
  • Password: not set
  • Server: not set
  • MMSC: http://wholesale.mmsmvno.com/mms/wapenc
  • MMS Proxy: not set
  • MMC: 310
  • MNC: 260
  • Authentication type: not set
  • APN Protocol: IPv4
  • APN roaming protocol: IPv4
  • APN enable/disable: APN enabled
  • Bearer: unspecified
  • MVNO type: none
  • MVNO value: not set
After you have corrected punched in the correct APN Settings, you need to SAVE it,
Reboot your phone and test it, SOURCE: I have a zte z832 unlocked cricket phone and I put my life wireless SIM card from the lifeline free phones in the phone and need to set the APN ..does anyone know the APN to set to this phone?
  • type it in exactly as it appears below.
  • APN: wholesale
  • Proxy: not set
  • Port: not set
  • Username: not set
  • Password: not set
  • Server: not set
    mmsmvno.com
    /mms/wapenc
  • MMC: 310
  • MNC: 260
  • MVNO type: none
Press the Menu key and save. Reboot your phone and test your data connection by opening a web page.
2answers
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
Tmobile samsung dart i cant access web only trough wifi does it work
Probably the data is off, try going to Settings, More, Mobile Network, and check the Data Enable box. If you still can't get internet by enabling data, then your APN must be off. If you are still with T-Mobile, then go to Settings, More, Mobile Network, Access Point Names or APN. From here you can see which Access Point is check, troubleshoot by checking one of T-Mobile's APN and trying to use the internet without Wi-Fi.
1helpful
MMS Settings on Simple Mobile
I posted this answer many days ago on the other thread of yours, but I got no feedback from you so far. I'll reproduce it here, anyway: Starting from any of the home screens- Press Menu- Tap "Settings"- Tap the "System" tab- Make sure that "Airplane mode" is unchecked- Tap "Mobile Network Settings"- Make sure that "Data enabled" and 'Always receive MMs" are checked- Tap "Access Point Names"If there other APNs are already stored- Select APN- Press Menu- Tap "Delete APN"- Repeat the above steps for all remaining APNsNow define the Simple Mobile APN- Press Menu- Select "New APN"- Enter the following information:-- Name: SIMPLE Mobile-- APN*: simple -- Proxy: <Not set>-- Port: <Not set>-- Username: <Not set>-- Password: <Not set>-- Server: <Not set>-- MMSC: http://smpl.mms.msg.eng.t-mobile.com/mms/wapenc-- MMS Proxy: <Not set>-- MMS Port: <Not set>-- MCC: 310-- MNC: 260-- Authentication Type: <Not set>-- APN type: <Not set>
*the APN field is case sensitive
- Press Menu- Tap "Save"
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
I don't know how to enable the GPRS of my phone Samsung Gt-i7500
My Suggestion is that , Do 3 Steps, then your GPRS will be enable...
1. Open: Settings -> Wireless -> Mobile Network -> Internet access points.
2. Create a profile for the Internet:
APN: internet.tele2.ru
MCC: 250
MNC: 20
APN type: default
The rest of the field: leave it blank.
3. Press Menu -> Save setup is complete.
1helpful
I cant seem to get onto the internet on my Galaxy s. I can get onto it through my wireless at home but not through my provider even though I get an unlimited accsess. Rob
Check your APN is enabled.If you are using any apps like apndroid etc make sure you enable it. If not due to the third party apps, make sure the APN's are indeed configured properly. If not sure you may request your service provider to send the apn settings again to your phone.
Enabling Edge
You need either GPRS enabled with your SIM card or WI-Fi enabled.
For GPRS enabling, go to Settings ->Network->EDGE->APN -type your SIM Card GPRS site address, ask your SIM provider for the details. Username-put your phone number with country code and Password-put what is there for your SIM.
For Wi-Fi enabling, go to Settings -> Wi-Fi-set it to ON and it would automatically search for nearby connections. If you find one unlocked, just select that and start using internet via SAFARI!!!
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
