They have headphone and mic jacks, but the headphone does not override the speakers, so I get sound from both. Is this by design, or is there something I don't know about?
The bass unit powers speakers. there is no headphone jack. Now on your computer there is, you can configure to turn off speakers when plugged in.
Incorrect. There are headphone and mic jacks on the side of the left desktop speaker that has the volume and subwoofer controls. I'm looking right at them.
sorry I ended up with 635. I cannot find manual anywhere.
Nor can I.
SOURCE: Boston Acoustics Digital BA735 Speakers with no Analog input.
I use one set of BA735 with two computers. Computer A sends digital out
and Computer B sends analog. BA735 plays both. I listen to music using
digital while the analog from the other computer alerts me to the
incoming messages in Pidgin.
I did have to change bios settings on one computer to use the on-board audio.
To enable digital output in XP, click on the speaker icon > Advanced
> Select Enable SPDIF. You can leave the PC Spk Mute unchecked if
you want the analog output as well. That's all.
I hope you are able to enjoy the rich sound of BA735. It's beautiful.
My ears thank a lot for replacing those desktop speakers. BA735 hardly
takes up any space . Two small speakers are perched on the hutch and
the bass module is somewhere behind the desk, completely invisible.
SOURCE: Dell latitude D620, no speaker sound
you will have to uninstall your audio device, and uninstall SKYPE and re install the audio device and don't re install SKYPE, you can do this by going to add or remove programs, and remove SKYPE first and unplug u r headset and mic, and after removing skype you can reboot the computer, and sometimes the conflict is resolved, otherwise then go into your device manager in system manager and find audio devices, unistall the driver or Update the driver, and reinstall it and the reboot, that should take care of the problem.
SOURCE: Boston BA7500G Speakers with no sound.
Well we have eliminated the laptop as a problem,.. that is very good. As far as what the problem with your BA unit is,.. we only know that it does not function with an external device (laptop and mp3 player). you already mentioned that a sound test from the unit plays through all the speakers,. right? With that lets start with the most basic item that will cause this problem,.. the cable that comes from the BA unit and plugs into the laptop or mp3 player. Is the cable plugged into the right place on the BA unit? Does the cable disconnect from the the BA unit? if so, do both ends of the cable look the same or is there 2 ends (maybe red and white) that plug into the BA unit? Please let me know when you can and we can continue troubleshooting this.
SOURCE: Headphone jack of my laptop does not work
You have to set the software in order to connect the wright way. with a USB device it will never work.
go to the properties of your audiocard and theire select what you want
SOURCE: My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
