Hi Henry.
see if this link will help you out.
Samsung Washing machine won start Google Search
SOURCE: Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
SOURCE: Hotpoint WT960
its either a fill valve or you water taps are faulty ie; rounded off knobs easey fix please leave feedback good luck
SOURCE: washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
SOURCE: model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
