SOURCE: need firing order for a 86 chrysler outboard boat engine
Firing order 1 2 3 is common on most three cylinder outboards. 1 3 2 is the only other combination.
SOURCE: miss fire on number 1 cyl
I would have to say that I think it's not miss fireing.
It could be the coil for those 2 cyclinders. It could be in the carbs. When you cleaned the carbs did you remove them from the engine and dismantel them completly? Clean every parts and blow out all the air and fuel ports. Did you seperate the carbs from each other? If you did the carbs will need to be synced again. Good Luck.
SOURCE: idleling only 2 of the 3 cyl. working if you open
I had one.....make sure the linkage is hooked correct. If it works when you do it by hand the linkage may not be working...??
SOURCE: i need wiring diagram for boat 1993 Bayliner jazz
can't start my 1993 bayliner 1400 jazz. replaced key switch, kill switch today. I got the boat last week running.
