Question about Toshiba Computers & Internet
Restore toshiba satellite C655D-S5300 to factory setting without discs
Posted by Russell on
TOSHIBA RESTORE TO FACTORY SETTINGS WITHOUT DISC OR BIOS PASSWORD
The only way you can manege to restore to factory settings without a cd or a BIOS password is when you remove the hard drive from the pc, slave it to another computer and make a backup of all the data and then format it as an NTFS and then put it back into its computer and then install a new operating system
Sep 09, 2013 | Toshiba Satellite L755-S5158 Laptop
Toshiba no bootable device--insert boot disk and press any key
try booting from a Windows installation disc. Choose the repair installation option. If this does not work, you may have to erase (format) your whole drive and start over again by reinstalling Windows from scratch.
Before erasing the drive, you might want to pull it out, put as a second drive in another working computer or inside a USB hard drive case and download all of your information from it. Otherwise you may have a mess on your hands with lost data/documents/photos.
Jan 21, 2013 | Toshiba Satellite C655D-S5084 Laptop
Error 0x80070002
You have a virus/malware infestation. Bring it to a repair shop and let the pros fix it.
Jul 22, 2012 | Toshiba Satellite C655d-5300
Toshiba satellite C655D-S5300 bios reset
To reset toshiba password, you can use Smartkey Product Key Recovery to help you, and you can see more detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Jun 13, 2012 | Computers & Internet
I have a toshiba satellite L645D how can I format it to the factory settings like it just came out of the box.
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1.Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2.Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3.Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4.Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5.Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6.Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thanks.
Sep 09, 2011 | Toshiba Computers & Internet
Cant restore to factory settings tried 0,f1 and f8 none work
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
Aug 16, 2011 | Toshiba Satellite Pro L300 Notebook
Selling my Toshiba laptop and I want to restore it to default/factory settings. When this was bought did not come with a disc.
Aug 16, 2011 | Computers & Internet
How to reset the toshiba l30s lap top to factory set up without the set up cd?
There is no way to restore it towards factory settings without the restore disc on your model.
May 03, 2011 | Toshiba Satellite Pro L300 Notebook
How do i restore my toshiba satellit pro a200 back
If you have a backup, you can do that, off your hard drive. Otherwise, you will need to get a replacement disk from Toshiba.
Feb 25, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
