SOURCE: Danby Dehumidifier DDR557HE has never dehumidified
either lacks coolant or compressor bad
Testimonial: "Thank you, I didn't even know a dehumidifier had coolant. "
SOURCE: Need a new Fan Squirrel
You can find what you're looking for at Appliance Factory Parts Just look through the parts available for your model.
http://www.appliancefactoryparts.com/dehumidifiers/danby/danby-motors-and-blades.html
SOURCE: I have a Danby Silhouette
Bryan, it may imply be a case of the humidity extraction level being set to high. Lower the level to 35% and see what happens. As far as the fan running is concerned. Most dehumidifiers are designed for the fan to run, even if the compressor doesn't turn ON. It's designed to keep the air circulating and if the humidity rises above the setting you have it on, the humidity sensor will pick up this change and turn the compressor ON.
Also, remove the air intake filter to see if it's clogged and needs cleaning. Maintain at least a minimum of 12" of free air space all around the dehumidifier. Poor air circulation will prevent the unit from working properly. As will, to low an ambient air tempeature. Most unit struggle to work at temperature between 40 & 60 degrees F.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
SOURCE: need instruction manual for Danby Silhouette
Well can't seem to find your particular model but they have what looks like yours
http://www.needinstructions.com/search/?q=Danby+DDR600R+Silhouetteumidifier+MANUAL&page=3
SOURCE: I need a manuel for
Unfortunately, the model number you listed has been discontinued. But is still supported thru the Danby Consumer help line: 800-263-2629. Contact them regarding your need for the Owner's Manual and they can email you one as an attachment.
I hope this helped you, Susan. Thanks for choosing FixYa.
Testimonial: "thank-you very much"
