Question about Tamron Cameras
I cannot manually focus my Tamron 79-200mm 1:2.8 lens
Posted by Barbara on
  • Tamron Master
  • 18,666 Answers
Mark Cheong
    Master:
  • 791 Answers
First, I'm not a TAMRON Tech.
* Check your warranty and call for service.
* Ah, Found this on you tube. (VERY Technical!)
https://www.youtube.com/watch?v=o9dvQmVAhK0
* Strongly suggest you have this lens serviced.
Aloha, ukeboy57
Posted on Jul 02, 2018
5 Related Answers
Scargo
  • 51 Answers
SOURCE: auto focus problem
My first suggestion is to send it back if it is under warranty.
The grease probably got so thick, from the cold, that it caused too much resistance for the auto-focusing mechanism. You probably have damaged the focusing mechanism in the lens. You cannot repair this, yourself. I don't know how cold is too cold but it really shouldn't have done that.... Tamron makes cheap lenses. Try and exchange it for at least a Sigma.
Posted on Dec 29, 2007
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: Tamron 90mm 2.5 adaptall man focus lens
You probably have to set the aperture manually on the lens, because it might not have CPU contacts. I think changing the aperture on the camera will probably have no effect, so just try twisting the aperture ring to wide open.
You usually have to set the aperture at the minimum setting (highest number) so that if the camera is choosing the aperture, it can stop down to the required value.
No good having it set at f2.8 if the shot needs f11.
If the lens is very old, it might have a manual iris that you have to set yourself on the lens. The lenses that stop down automatically will have a tiny peg on the mount that a suitable camera can operate. Gentle pushing of this peg while looking through the lens will tell if it is stopping down - set it wide open first.
If you have a depth of field preview button, this will also have the same effect with the lens on the camera if the body matches up with the lens.
Posted on Jan 17, 2009
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: bought a tamron 28-300mm Di LD lens for my Canon
Nothing you can do. The Tamron is not compatable with your camera. So the focus will be slower
Posted on Apr 24, 2009
Anonymous
  • 3006 Answers
SOURCE: Have a two month old 18-270 Tamron lens. Used it a
If it's only two months old then it's still under the manufacturer's warranty so send it back to Tamron. I can't tell you where to send it as you haven't said which country you're in. Tamron value their reputation and usually provide excellent after-sales care.
If you're in the UK you additionally have Sale of Goods Act protection for up to six years in England and Wales and five years in Scotland. Either way, the Act allows you to demand a full refund or replacement from the retailer; I'd suggest a refund as bad lenses often come in batches and a different supplier is less likely to have one from the same production batch.
Note that any attempt to fix the lens other than by normal use of the lens and camera controls may completely remove your warranty benefits or consumer protection.
Posted on Oct 28, 2009
fikretunalir
FIKRET UNALIR
  • 239 Answers
SOURCE: Tamron lens makes a clicking noise
It is dealing with the films. when closing the lens in the fabric, the electrical film changed its position to an unwanted situation. This makes noise sometimes. It is not important for functinality of the lens. But it only gives you an unwanted noise. There is nothing to do because film dries as the times passes. It needs to be changed but is not cheap. So it is better to go on to use it.
Posted on May 28, 2010
Can Tamron 2 X converter C-AF 1 BBAR MC-7 mounted with Canon 100-400mm? Tks
As you can read in the Dpreview link the Tamron converter can work perfectly with the Canon cameras. Question is, will AF still work, because you have to multiply the aperture twice. So if your lens has f/1:5,6 that will become f/1:8. Most camera's can't auto focus anymore on F 8
link to Dpreview Tamron 2X converter
Oct 15, 2012 | Tamron F AF TELE-CONVERTER 2X C-AF1 BBAR...
Was I sold a 'pup'? Tamron lens box says AF55-200mmF4-5.6LD MACRO. Can't find macro setting on lens or instructions. Looking at your site, Product Details says 'No Macro'. So what's...
Excerpted from a www.photo.net review of the lens:
Though the Tamron AF 55-200mm Di II LD Macro has "Macro" in its name, it's not really a macro lens. Maximum magnification is about 1/3 life size (Tamron spec it at 1:3.5) as you can see from the following image below, which was shot at 200mm and at the closest focus distance (0.9m/37.4"). This isn't too bad, but it's more of a close focus telephoto lens than a "macro" lens (bolding for emphasis added).
Sep 09, 2011 | Tamron 55-200mm f/4-5.6 Di-II LD for Canon...
Wil the Tamron AF 80-210mm 1:4.5-5.6 fit on my Nikon D3000 and if so how does it perform?
Assuming the lens has a Nikon mount, it will fit on the D3000. Tamron makes their lenses with a variety of mounts, so that one with a Canon mount, for example, won't fit onto a Nikon body.
This lens lacks an autofocus motor so you'll have to focus manually. Other than that, it will work fine. It's not the sharpest lens available, but it's also not the most expensive.
Apr 05, 2011 | Tamron 80-210mm f/4.5-5.6 Lens
The Quantaray 70-300mm lens
Only if you get the version with the built-in autofocus motor. The D3000 lacks a mechanical AF coupling so AF lenses which need to be driven by a motor in the camera body will require manual focussing.
Either way, you're far better manually focussing the Quantaray/Tamron 70-300mm: the AF performance is very slow, very noisy and hunts around a lot to achieve focus.
Although the Quantaray and Tamron versions are identical lenses, if you have to buy this low-quality budget model then go for the Tamron: it's absolutely no better lens quality (and usually the same price), but the manufacturer's warranty from Tamron is much better than Ritz and is internationally valid. If you resell the lens then the Tamron will have some value (not much though) and the Quantaray will be near worthless as it's not so widely known, and has a poor reputation amongst those familiar with the brand.
"Cheap" isn't always the same as "good value"...
Mar 06, 2010 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
Detaching Lens Hood
I'm not sure of the exact model number of your lens, but the hood should have a bayonet flange and rotating it in one direction or the other should allow it to then simply pull off.
Nov 12, 2008 | Tamron Macro 90mm f/2.5 Manual Focus...
Tamron 28-200 AF Aspherical LD. Does it have manual focus? If yes, where?
There should be a switch just in front of the back of the lens marked "AF" and "M". Set it to M for manual focus, AF for autofocus.
Aug 30, 2008 | Tamron 28-200mm f/3.8-5.6 LD Aspherical IF...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Auto focus problem
Dec 24, 2007 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Cameras Logo
Top Tamron Cameras Experts
Steven Wander
Steven Wander
Harrie
Are you a Tamron Camera Expert? Answer questions, earn points and help others
