Question about Laser Office Equipment & Supplies
My Ultra 1000ap shuts down whenever my laser printer starts.
Posted by David Chamberlain on
2 Related Answers
Doug Jordan
  • 28 Answers
SOURCE: system shuts down when printing to dell 1700 laser printer
You may have a 'recalled printer' Check out this link!
http://support.dell.com/support/batteryrecall/index.aspx/en/main 1700/1700n Printer RecallIn cooperation with the U.S. Consumer Product Safety Commission, Dell is voluntarily providing the Customers who purchased the 1700/1700n printer (from June 8th, 2004 - August 18th, 2004) a free replacement printer. [Announced September 7, 2004]
Posted on Feb 12, 2010
Grandpa Fixi
SOURCE: How to correctly install batteries in ultra model
Place your two new type CB1270 batteries on their sides, one on top of the other in front of you with the battery connectors closest to you and with the battery connectors to your left. Connect the short (2 inch) jumper cable between the two center battery posts (1 red/1 black). Slide the battery stack into the chassis with the battery posts to your left as you face the front of the UPS and be careful that the battery posts do not touch the metal chassis. When the batteries have been slid completely into the chassis, connect the heavy red wire from the circuit board to the red battery connector at the bottom of the battery stack and the heavy black wire from the circuit board to the top black battery connector. If you have doubts about your wiring, use a DC voltmeter set to the 50v range and touch the red probe to the red battery post at the bottom of the battery stack while touching the black probe to the black battery post at the top of the stack. The reading on your meter should be somewhere between +24 and +26v depending on the charge level of your batteries.
Posted on May 01, 2011
Why does my Harley Davidson 2003 Ultra Classic shuts down when hot?
Thermal safety cutout is shutting down ignition, if you don't feel the engine is that hot replace thermal cutout and relay
Aug 08, 2014 | 2003 Harley Davidson FLHTCUI Electra Glide...
My printer hp laser jet 1010 series's Red Light next to the triagle keep blinking whenever i start it.
Open all doors, remove toner, reinsert toner and shut door. Shut off the printer. Wait.....Turn printer back on.
If red light is still flashing, go to: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00028320#A0 to help identify what it might be. This is an HP site so it is safe.
May 17, 2011 | Office Equipment & Supplies
Can not print envelop with Dell 1110 Laser printer.
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
restart the computer:
  1. Click Start and then Shut Down.
  2. Click Restart.
    The computer restarts.
Nov 02, 2010 | Dell 1100 Laser Printer
I have photo transfer paper for laser printers. It suggests setting the paper setting for ultra heavy paper. How do I do this?Will this paper from "Tulip" hurt my printer?
go to start, programs, printers, right click on your printer and then left click on properties.
after that there should be an option for your printing preferences. from there you should be able to select your paper type.
using transfers should not damage your printer as long as it is a laser grade paper
Dec 27, 2009 | Brother HL-4070CDW Printer
Lost my instalation cd so pls want edgemodem driver model:E67II
Post a request on this website, seemed to work for another user of an edge modem!
Jun 29, 2009 | D-Link DWL-1000AP and DWL-120 Wireless USB...
System shuts down when printing to dell 1700 laser printer
May 11, 2009 | Dell 1700 Laser Printer
HL-1250 shuts down by itself
Sounds as if this is an overheat or a short circuit. you may require a new laser engine or power supply. Disconnect the laser motor from the power supply and them turn it on. If your led's stay on, it's the laser engine. If not, it's the power supply.
Apr 09, 2009 | Brother HL 1250 Laser Printer
Hp photosmart printer c4280 all in one error message
Is it make your PC shut down.
Please uncheck the printer from Msconfig:
Start --> Run --> Type in --> msconfig --> go to Start up Tab --> uncheck printer entries -- > Reboot PC.
Then check for it. Let me know if I can assist you further.
Regards
Ellin
Sep 25, 2008 | HP PhotoSmart C4280 Laser Printer
Applications shut down when printing
Try to uninstall and reinstaing the s\w...might fix
Apr 25, 2008 | Lexmark All-in-One Printer with PictBridge
20 people viewed this question
Top Laser Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Barbat Nae
Barbat Nae
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
