SOURCE: car noise: loud grinding/pinging. Louder
Could be anything from a bad knock sensor to an internal engine problem. Try a stethoscope test if you can duplicate this racket while in park.....accordianman
SOURCE: 2008 malibu service esc traction control and eng
The torque converter clutch circuit may be at fault. The best way to determine the problem is to have a scanner/computer to read check engine codes.
SOURCE: I accelerate my 2000 neon, and it vibrates and get grinding noise
Check the front drive axles and boots. A bad cv (constant velocity) joint can cause this.
SOURCE: Audi A4 - Strong vibrations while accellerating and while idling
If it had points and carb i could diagnose it but with all this computer control stuff it could be anything from a faulty sensor to a dodgy fuel pump or evan a multiplug loose .i would suggest the dealer to diagnose it sorry i cant be of much help but evan the software is encrypted and the vehicle has to be connected via the internet to stuggart
SOURCE: Harsh grinding noise while in gear and car won't drive!
Had the exact same thing in my 93 and it was the CV Axles - they have a C clip that hold them in place - sometimes the C clip and fail; sometimes you simply have to replace the CV Axles - much cheaper then a tranny; a good suspension shop should be able to diagnos w/o it costing you an arm and a leg.
