Question about Daewoo Refrigerators
SOURCE: Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Posted on Sep 26, 2007
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
SOURCE: Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Posted on Jan 18, 2010
SOURCE: My Dometic rv Refrigerator does not cool the lower
If the freezers ok, then airflow is the issue, as the reefer gets its air from the freezer, set the dial that does not operate the compressor to the middle setting, pegging it to cold, makes the freezer colder by starving the reefer!, very common call requiring no repair , just a setting change!! never peg it!!
Posted on Jul 19, 2010
SOURCE: lec tf 5586 freezer section not droping to lower
the freezer does not freeze properly only 2 years old
Posted on Sep 23, 2010
Oct 17, 2014 | Daewoo FRAU20ICB Black 561 l Fridge...
Jan 10, 2014 | Refrigerators
Nov 15, 2013 | Refrigerators
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Refrigerators
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Feb 21, 2009 | GE GSS20IEP Side by Side Refrigerator
May 20, 2008 | GE Profile Arctica Stainless Steel Top...
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Feb 25, 2020 | Daewoo Refrigerators
139 people viewed this question
