Question about Nakamichi Televison & Video
My nakamichi ns4200le 3d smart tv shows that the launcher,tv app provider and the system settings has stopped continuously
Posted by Sithija on
5 Related Answers
Anonymous
  • 542 Answers
SOURCE: apps in LifeDrive partition don't show up in Favorites or built-in Launcher??
Yes, your choices are a third party launcheror apps that create shortcuts to apps on your drive such as PowerRun. Personally, I am using PowerRun version 1.3.1. It has been working great. No problems.
Posted on Sep 15, 2005
Anonymous
  • 542 Answers
Anonymous
  • 113 Answers
SOURCE: message: launcher has stopped working. Need solution
First question is do you have the vista disk ? If so , here are the steps to repair. Insert disk ....instead of selecting install vista , after the language selection box , select repair a menu will then be shown with the options you can choose from , choose start-up repair , this will repair missing files or disk errors. once selected no more input is needed from you. Hope this helps !
Posted on Jul 28, 2009
grimreaper12
grimreaper12
SOURCE: i set a broken app as a main launcher and now the screen stays black
Turn off then back on
Posted on Jan 12, 2012
gopakumarg43
  • 76698 Answers
SOURCE: No Facebook app on optica smart tv
What is the exact model number to your TV? Look for this detail, at its back cover. Gopakumar Gopalan Google
Posted on Apr 26, 2014
Testimonial: "Model no 7042. That's all it says. Sku is t844 not sure what that is thought I'd put it on here incase any good. Have you an idea what to do?"
tip
HOW TO FREE MORE RAM ON YOUR S60 MOBILE
<p><b><span style="font-weight: bold;">How to free more RAM on your phone&gt;</span><br /></b><br /> <p><b>Method 1: Flight mode:</b><br /> <p>Put your phone in "Flight mode" with Psiloc System Tools. Install System Tools, open it and select "Flight mode". This way you can restart the phone without your SIM card so there will be no running phone tasks in the background. Now you can have up to 3,5 MB of free RAM!<br /> <p>Note: ironically enough, Flight mode doesn't work when Smart Launcher is installed, at least in my case.<br /> But i've also heard several reports of people who have both apps running without any problems.<br /> <br /> <p><b>Method 2: Smart Launcher trick:</b><br /> <p>Install Smart Launcher and open it. Go to Options, Settings and put Launcher ON.<br />Now plug in your charger and switch off your phone. Wait untill the battery meter appears and short press the Menu button (don't hold).<br /> The menu should appear and now you can have 3,5 to 4,5 MB free RAM! (Hold Menu button to check RAM).<br /> <p>The trick is that with the charger plugged in, the phone must get a minimum software support for charging, even when<br />the phone is switched off. And somehow Smart Launcher has still got it's shortcut running and that's the Menu button. So when<br />you press the Menu button, you go directly to the Menu without any other phone tasks running in the background so<br /> you trick the phone and you have more free RAM!<br /> Note: when you unplug the charger, the phone will switch off.<br /> <p><b>Method 3:<br /></b><br /> <p>It frees a little about 100~200 KB but I guess it's useful sometime. Close your menu not by selecting the right selection key "exit", or pressing the menu key another time, they only hide the menu app but do not close it, to close it select the left selection key "option" and scroll down and select "exit"<br /> <p>So when you open an app needs more ram reopen menu and close it, it's useful when play low bit rate video in realplayer paradis.<br /> <br /><br />
on Mar 04, 2011 • Cell Phones
Hi. How can I add cwtv app on my Samsung LED smart tv?
Android tablets and phones are smart enough to play all apps from Google play. However, so-called smart TV's are rather immune, and only play a very limited number of apps from the site of their own maker (so Samsung TV's play a few Samsung apps, LG TV's play a few LG apps, and so on). Your observation is quite right.
http://electrohelponline.blogspot.com/
Need to reset netflix on new smart tv
try a software update on the tv. or go all out with an apple tv as the picture quality is amazing compared to nearly all smart tv apps
Ok I am having trouble with my Android Craig tablet. There's a message keeps popping up on my screen an it's blocking me from getting to my stuff. The message says "The application Launcher (process...
Phone is getting an error message: "Unfortunately Launcher Has Stopped."
Unfortunately Launcher Has Stopped:
  1. Swipe your finger from top to bottom on the screen to view the notification panel
  2. Touch the Settings or
  3. Touch Apps
  4. Touch Menu or
  5. Touch Reset App Preferences
  6. Touch Reset Apps
  7. Swipe from right to left 2-3 times to show the ALL list.
    (For device running on Android 6.0.X touch Menu then Show system)
  8. Touch Launcher
    (For device running on Android 6.0.X touch Stock Android then Storage)
  9. Touch Clear Data
  10. Touch OK
  11. Power Cycle Phone
  12. Test phone
hope this isn't clear as mud. :) and helps you
Nakamichi tv
My smart tv nakamichi, while swith on only shows android and busy, even remote not functioning. . Pls advice
Televison & Video Logo
Top Nakamichi Televison & Video Experts
ray gallant
Tom Chichester
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
