Question about Golf
My charger does not light up at all when I plug it into the golf cart nor does the light on the cart
Posted by Dorothy Tolbert on
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
Posted on Nov 27, 2008
Anonymous
  • 24 Answers
SOURCE: I have a yamaha electric golf cart. The lights
I bet that it is an simple as a fuse that blown out. Try replacing the corresponding fuses.
Posted on Nov 07, 2009
Anonymous
  • 82 Answers
SOURCE: I have 2004 EZgo electric golf cart. When I plug
Check for a tripped circuit breaker. usally at inline with the positive cale of the battery
Posted on Mar 25, 2010
golfcartman
  • 34 Answers
SOURCE: My 2000 Yamaha golf cart has 6-4cell 8 volt
Yes to both questions. the charger must sense 41.5 volts to activate the relay inside the charger. Being a repair shop, I have a charger that is rigged to charge even DEAD batteries. I do not recommend this for the novice. A charger set on 12 volts will bring the batteries back up to 8.2-8.6 volts. A cheap trickle charger may not put out enough to charge a battery of this size. Remember that they are used to MAINTAIN a charge. Connect the Voltmeter and watch for voltage rise. If it rises to 8.1 or above, it is charging. Trojan battery company recommends charging at least once a month.
Posted on Apr 21, 2010
jim nicholas
  • 3 Answers
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Posted on May 15, 2012
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
Jan 24, 2016 | Golf
How do I connect 36 volt battery charger to electic golf cart?
Maybe you have an Ezgo cart? Black is negative, white is positive, and the small red wire is connected to the white inside the charger receptacle.
Sep 04, 2015 | Golf
Charger works but cant get it to charge when plugged into my cart 48 volt
This can be one of several problems. Make sure charger works on another cart first. If it does then check total voltage of your cart, has to be at least 42 volts before charger will turn on. If you plug in the charger and it does not turn on then listen for a small click from inside the charger. That would be the relay and if it operates then your voltage is ok and you have something else wrong. If you don't hear the click then check the small gray wire at charger receptacle. It sometimes breaks just inside the receptacle, Without this sense lead, charger will never turn on. If all batteries, wiring, sense lead, fuse in the sense lead are ok, then it might be the OBC (on-board computer).
May 13, 2015 | Golf Cart Parts & Accessories Energy...
NO POWER WHEN PLUGGLED IN
Battery charger is probably of the intelligent type containing sophisticated circuitry which is very vulnerable to being damaged or weakened by excessive heat, voltage surges and transients. Such chargers should really be used with additional surge protection.
When such a charger fails to work there is little an owner can do other than check the supply and the fuses and connectors, both on the charger and on the golf cart. If everything that can be tested is ok it is the task for an engineer to carry out repairs.
Feb 12, 2015 | Dual Pro 48V 18Ah Yamaha Golf Cart Battery...
What should I check to see why my charger won't charge the golf cart? The charger does work, but when the charger is plugged into the cart it will not charge.
There is a switch in the plug that will keep it from engaging. You said that the charger is working. How is it that you determine this? A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Sep 26, 2014 | Golf
Why don't I get power to the motor on my Golf cart and how can I fix it.
BuggiesGoneWild has all types of poems. Please visit their website. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Aug 21, 2014 | RHOX Yamaha G14, G16, G19 Golf Cart 6"...
Why is the EZgo Charger fault light is on
Have all battery checked
xxxxxxxxxxxxxxxxxxxxxx
Jul 18, 2014 | Dual Pro 36V 25Ah Golf Cart Battery...
Golf Logo
242 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
