SOURCE: How do i fix error 98.01.01 on a HP Laser Jet 600 M603
This error is caused by a corruption of the harddisk on the printer. Download the current firmware for the printer from Hewlett Packard. Then restart the printer and watch the display. When you light on the screen comes on press the orange X button. This will open the preboot menu. Use the arrow to go down to Administration, press ok and then select the option to format the disk. You will get a warning that you will need to reinstall firmware. Click ok. Go to the download firmware option, select ok and then select USB Key option. You will be prompted to insert a USB stick, insert the one you copied the new firmware to. You will be prompted if you want to install the firmware. Click ok and then use the back arrow key to exit until printer says continue. Press OK. Printer will restart and firmware will be updated and printer should now come to ready.
