Question about Pitney Bowes Office Equipment & Supplies
Solution of error code c0600 for pitney bowes
Posted by Asif Akram on
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Posted on Sep 02, 2008
Anonymous
  • 18 Answers
SOURCE: New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
Posted on Aug 24, 2009
Nike Merritt
  • 149 Answers
SOURCE: Pitney bowes fax machine model 1630 has 76 error
The heater lamp in the fuser is broken. Call 1 800 243 5556 for service.
Posted on Nov 28, 2009
J Anderson
  • 159 Answers
SOURCE: I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Posted on Dec 22, 2009
Testimonial: "I followed your tip which produced a contact# that led to the needed answer."
Nike Merritt
  • 149 Answers
SOURCE: 9720 Pitney Bowes Fax - access code has mysteriously been placed
Function 9, access code is 9720, press yes, press no until you get to set access code? press yes, delete code, press yes, press stop. I don't think this manual in online any more, but you can go to www.oceusa.com, go to drivers and support, and look for 9820 or 9800 series. The programming instructions are the same as this model
Posted on Dec 24, 2009
Pitney bowse every time show this messages
We need your model number.
Also check your toner cartridge carefully. A toner that is not fully locked in can cause this error.
Oct 30, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes fax machine model 1630 has 76 error code, what does it mean
Oct 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes model c400 copier error 0070??
Sincerely,I don`t know this model,but the error codes is similary to the Agfa,Minolta,Konica copiers.This code is the toner agitator motor malfunction code.The developer station is blocated under minimal level of toner ratio.In this case forced toner supply.Opem amd close the front door to reset.
Aug 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
May 17, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Jan 19, 2009 | Pitney Bowes C180 Copier
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
Pitney bowes 9720 error
I've never heard of that type of error. After going through Pitney Bowes vast database, the searches turned up with nothing worthwhile.
Do you have any other information I can use to further assist you?
Please let me know if this helps. Good luck!
Feb 29, 2008 | Pitney Bowes 9920 Plain Paper Fax
26 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
