SOURCE: Maytag Neptune front load door is stuck
Pull cord under soap tray.
Read here:
http://www.applianceaid.com/neptune3.html#lock
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
SOURCE: Please help! My samsung 7kg J845 front loader
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
SOURCE: LG front load washer coded UE. what does that
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
SOURCE: my samsung 7kg front loader keeps flashing UE on
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
