Question about Nikon Cameras
Directions for using different settings on the camera
Posted on Jun 29, 2018
SOURCE: I attach Nikon CoolPix S550
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
Posted on Nov 25, 2009
SOURCE: Just bought a Nikon Coolpix S8100. After
You will need to install a codec pack on your computer to resolve this problem. Download and install the codec pack from the link below and see if it resolves the issue.
http://www.free-codecs.com/download/k_lite_mega_codec_pack.htm
Posted on Dec 10, 2010
SOURCE: nikon coolpix s8100 will not turn on. i have only
If it won't turn on, you're not going to be able to reset it.
Other than sending it back, the only suggestion I can make is do you have or can you borrow a spare battery. If so, try that. It could just be a failed battery.
Posted on Aug 26, 2011
SOURCE: how do I fix my Nikon COOLPIX S8100 flash
Check the camers's flash setting, make sure the flash has not been turned off.
Also check the batteries, make sure they are fully charged, a low charged battery will not charge up the flash capacitors.
Posted on Nov 17, 2011
SOURCE: nikon coolpix s8100 lens error lens won't
My s8100 bought easter 2011 fell down and now it has a lense error ! What should i do ????
Posted on Mar 14, 2012
