Question about Bulova Watches
Bulova Millennia With Vibra-Alarm 98A48 Wrist Watch Change do you need to re start the watch by touching postive and negative on the inside back of the watch?
Posted by Abraham Rivera on
The poblen water inside
Get it dried out as soon as possible as rust starts in as little as 48 hours. Then find out why it leaked. You will need a watchmaker
Oct 10, 2012 | Bulova Millennia With Vibra-Alarm 98A48...
Looking for instruction manual for Bulova 98A48
I could not find your watch on their web site, perhaps it is discontinued?
You may find a watch that is similar to yours however.
If you go to "Boluva.com", you will find a menu at the top of the screen. Click on "service centre" and you will see a list o watch types; click on "boluva" and you will arrive at a list of instructions.
A search of these might help.
Otherwise try their repair service, who might be able to help you.
Jul 23, 2011 | Bulova Millennia With Vibra-Alarm 98A48...
I have a bulova depthmeter millennia 200m A2 quartz where would i find this watch?
I have seen these watches sold on ebay, just make sure it is the genuine made by Bulova.
Jul 01, 2011 | Bulova Millennia With Vibra-Alarm 98A48...
Replaced watch battery on bulova millennia alarm and it skips to two second interval / I need to find out how to program it to 1 second interval
Watches, well most quartz anyway, are programmed to alert it's wearer to the fact that the battery in the watch is growing weak and needs to be replaced. There are watches that use a 2 second split and then there are those, like my Bucherer quartz that hops at 5 second intervals. Remember, just because you put a "new in the package" battery in your watch does not guarantee that it is new by way of battery power. Some batteries go completely dead while sitting on shelves waiting to be sold. For those of you that don't know, take it from a man of experience, never... ever... ever... store loose change and opened, new or used, coin or watch batteries in the same junk drawer. They will combine chemically to cook off the battery cells like a .22 rounds and pieces can fly pretty fast. Have a great day!
Jun 03, 2011 | Bulova Millennia With Vibra-Alarm 98A48...
My watch is ticking two seconds instead of one
The battery in your watch needs to be changed, this a warning the Bulova Millennia 98A48 gives before battery is drained.
Dec 14, 2010 | Bulova Millennia With Vibra-Alarm 98A48...
Help needd to find out how ro set Alarm on my Bulova Millennia 98A48. A users guide would be appreciated. I have lost mine.
Pull out the winding stem (crown) when second hand reaches 12 o'clock, set main time by ajusting stem, next press and hold A button "near 9 o'clock" hands will move quickly, when close to matching main time, release A button and press in and out quickly until it matches main time. Next push winding stem in, this will start the main and the sub-hands together for normal time. To set alarm press and hold A button until set time is reached, select B button alarm mode "2 o'clock" for beep or vibra, to turn alarm on/off press C button "4 o'clock" for 1 or 2 seconds, the sub hands will move rapidly until it reaches normal time and alarm will sound 3 times indicating it is set, finally when alarm goes off early in the morning for example you can press any button to stop. To reset alarm press C and it will go back to the original alarm setting.
I have a spare set of instructions if required.
Aug 07, 2010 | Bulova Millennia With Vibra-Alarm 98A48...
I was wondering where to find the seiral number of my watch or how to identify what model number it is
The model sometimes is on the case back or inside the case back and the serial number inside on the movement. Therefore you would have to remove the case back. Be careful if you do this so you do not damage the case. Maybe better to have a shop do this for you.
Nov 20, 2009 | Bulova Millennia With Vibra-Alarm 98A48...
Small hand on Millennia not keeping time
From your book, start from square one. Second hand to 12 Pull crown to stop second hand.Set sub hands to duplicate main hands (correct time) Push crown in. I'm not that clever , I got the jeweler to do it for me.
Nov 03, 2006 | Bulova Millennia With Vibra-Alarm 98A48...
Watches Logo
223 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Are you a Bulova Watch Expert? Answer questions, earn points and help others
