Question about DeLonghi Dehumidifiers
How to remove the back off Delonghi dehumidifier dd50pe. Stuck around the handles.
5 back screws are out. Two side screws are removed, still the back is held tight around the handles. Thanks.
Posted by Elaynnea De Paulo on
  • David Mury Oct 20, 2019
    On the back there are two top screws, two middle screws, and one bottom screw. Make sure the hose attachment is off. On the front there are two bottom screws. Each side has one screw at the bottom (longer than the rest). Remove all that I have mentioned. You will need to wiggle the two halves apart but they will come. Once the back has been removed, there are two more screws on the inside that need to come out before you can get the front sleeve off. Good luck.
1 Related Answer
Anonymous
  • 159 Answers
SOURCE: Dehumidier Delonghi DH400P not removing any water from the air
Only thing I can tell you to do is to make sure that the evaporator in the back is ice and cold. If the evaporator is not cold the unit will never remove moisture from the air. And if that is the case you have a sealed system problem. The unit may have a leak so there is no gas in it. The compressor may not be working or the humidstat my not be working properly. So check those thigs out or if its under warrenty call for service.
Posted on Jul 12, 2007
My DeLonghi DD50PSC dehumidifies but the pump never comes on. Everything is ocnnected to the continuous draiining using the pump. Suggestions?
A blocked drain tube was the cause of the pump not working issue with this dehumidifier. I removed the back cover (5 screws on back, 1 screw on each side) and cleaned out the accumulated gunk in the small, clear reservoir on the back right. It took a little time using compressed air and pipe cleaners, but the effort ultimately worked.
Jun 14, 2012 | DeLonghi DE500P Dehumidifier
I have a Delonghi DH250R dehumidifier.It make a clicking noise every now and then when it is turned on. Is it that the thermostat trying to kick in to start the compressor ? And the dehumidifier is not...
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1& 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 06, 2011 | DeLonghi Dehumidifiers
No moisture removal. This is a DDH 30 model. How does one game access to the air filter for cleaning. I realize this is an older unit but has always performed well. Before purchasing a new...
Wayne, the filter may be in one of two places.
1. Turn the unit OFF & unplug it.
2. Remove the bucket from the holder. Look up inside the holder, just in front of the louvers and you may see a plastic pull tab type handle. This will be the handle to the filter frame. Pull it down and out of the unit. Since it sounds like it has never been cleaned, wash it in warm water and dish washing liquid. Rinse thoroughly and allow to completely dry, before reinstalling it. NEVER operate the unit without the filter in place, as it could cause damage to the unit
2. If the filter was not located in step 1, on the right side of the unit, just behind the louvers, there may be a pull open trap door. Flipping that door open, will give you access to the filter and it's removal. Clean it as described above.
The above are the only 2 places I know of, that the filter can be located in on a Delonghi
Dehumidifier. Unless, your unit is over 10 years old. In any event, I hope this helped you.
Jul 06, 2011 | DeLonghi Dehumidifiers
What does an E3 error code mean on a Delonghi DE500pc dehumidifier
Condensation sensor was tripped...needs to be dried/cleaned/repaired (on lint screen side remove plastic panel. The sensor is clipped to radiator fins.
Be Safe or don't do it....
On the side with the lint screen, remove the five screws holding the top panel in place. The sensor that needs to be checked in mounted on the radiator fins. Remove the sensor and 4 pin connector. With a pin, remove the loose fitting housing the "sensor"...a circuit board that "shorts" with condensation...check corrosion and look for component damage on the oft chance the circuit board was damaged by some inappropriate poking or mechanical failure. Reassemble and replace sensor...
For a short life span...or out of warranty and only at your risk (IF have significant other or kids or pets or human DNA... don't do this...) .. guide wire through screen notch and attach to outer screen. Build fortress around exposed sensor and talk to insurance agent for a special rider...seriously be careful.
Did you? Clean screen and GENTLY clean fins of lint, etc....(vacuum's brush head should do the trick...)
Taking all appropriate safety precautions.
Here's the 100,000 (yen) tip....with humidifier unplugged, hold down the power button (green button in lower center) and plug in the appliance.
Watch the LCD screen as it conducts a self test...and wha...lah!.
Dec 14, 2010 | DeLonghi DE500 Dehumidifier
What should I set it at
If there is actual water in the basement, any setting will probably cause the unit to run. I would suggest setting it around 60%, and turn it up as you feel necessary. Hope this helps
Apr 01, 2010 | DeLonghi DE500P Dehumidifier
Error Code E-3
i don't know if this will help i have a delonghi portable ac and the e3 means not enough voltage to run properly. but it was doing the same thing as yours. i plugged it in where i knew there was good enough voltage and it works fine now
May 26, 2009 | DeLonghi DE500 Dehumidifier
Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
May 17, 2009 | DeLonghi De'Longhi Energy Star174;...
Error code E3 on delonghi dehumidifier DH400P
Should have a working humidifier!
(your welcome).
no really..."de nada". :"don't touch your moustache" "Doye toche moche"(?), "prego".
Apr 10, 2009 | DeLonghi DH40P Dehumidifier
Jul 11, 2007 | DeLonghi DE400P Dehumidifier
Dehumidifiers Logo
318 people viewed this question
Top DeLonghi Dehumidifiers Experts
jdthefixer
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
