Question about Redfield Optics
I need a Redfield address. My scope is blurry.
Posted by Ivan Skinner on
5 Related Answers
Anonymous
SOURCE: Redfield Rifle Scope Manual
I own a Redfield spotting scope the model year is between the 70's to 80's and I need to find a manual for it. But I was Wondering if you could answer a question there is a crossair, then there is another one right above that, then there is a loop on the bottom right hand corner. There is also a yard marker that starts at 600 and goes down to 100. Do you know what it is and how to use it or what the purpose of it is if you could help me that would be great. Thank you for all your help..Joshua Gambler
Posted on Nov 26, 2008
Anonymous
SOURCE: Can a novice install a Redfield base and rings?
Problem solved. Redfield had all the size information I needed and mounting the base was a breeze.
Posted on Jan 17, 2009
Anonymous
SOURCE: Need to find a Redfield rifle scope repair shop-scope fogs up
iron sight inc.918-445-2001 4814 south elwood avenew tulsa oklahoma. 74107
Posted on Feb 19, 2009
Anonymous
SOURCE: I need a manual for a redfield rangefield 3-9 variable power
I found this info posted on another site. I saved it and will re-post for you. I hope this is what you were looking for: "the two lines across the top in your scope represents 18" which is the standard size for a deer's body from the top of his back to the bottom of his stomach. If you see a deer feeding in a field and you want to know how for he is, you turn your power up till the top of the deer and his stomach fit between the two lines at the top in your scope. You then look at the scale at the bottom of your scope and it will tell you how far he is in yards. I have one of these scopes on my 30-06. I am from East Texas and went on a hunt in West Texas several years back and everything out there looked like a 1,000 yards to me.
I saw these deer going around the end of a draw, and like I said it looked like they were out of range. I put the scope on the bigest and it said 250 yards, using it like descrided
above. I fired, killed the deer and when I steped it off it was 247 steps. I hope this answers your question."
Posted on Feb 20, 2010
Anonymous
SOURCE: can't adjust a Redfield Rangefinder scope
Found this info on another site a while back and saved it. Hope it helps! "the two lines across the top in your scope represents 18" which is the standard size for the deer's body from the top of his back to the bottom of his stomach. If you see a deer feeding in a field and you want to know how for he is, you turn your power up till the top of the deer and his stomach fit between the two lines at the top in your scope. You then
look at the scale at the bottom of your scope and it will tell you how far he is in yards."
Need address and phone number so i can get a redfield scope repaired
Here is the website for Redfield Support. There is a support phone number listed (1-877-798-9686).
http://www.redfield.com/support/
hope this helps
Dec 16, 2011 | Optics
I have a Redfield 3x 9x riflescope with a bent horizontal cross-hair. It is an old scope I've had for years. I was wondering if it is covered by warranty? If so,where do I send it for repair?
Redfield was purchased by Leupold in 2008, and is only able to repair and service Redfield scopes made in 2010 or later. If it was made before 2010, then it isn't covered by warranty, but Leupold does suggest contacting Iron Sight, Inc, if you want to ask about repairs and associated costs. Here's what the Redfield/Leupold website says:
When Leupold & Stevens, Inc.® purchased Redfield in April 2008, it did not acquire the capability to repair Redfield products manufactured prior to this purchase. The repair tooling and parts were purchased years ago by other repair services. Leupold & Stevens, Inc. will service its manufactured Redfield product (manufactured from 2010 forward) in accordance with its published warranty.
At this time, should a non-Leupold & Stevens, Inc. Redfield product require service, we suggest contacting Iron Sight, Inc. (918) 445-2001. This contact is provided for information purposes only, as Iron Sight Inc. is not affiliated with Leupold & Stevens Inc. They should be contacted directly for all information regarding repair, service and associated charges.
Feb 01, 2011 | Redfield Revolution Riflescopes
Need a pair of adjustment caps for a Redfield 2x7 Scope Where might I locate?????
go on line with redfield and look for there tech phone number and call them.
Mar 19, 2010 | Redfield See Thru Rifle Scope Mount Base...
I am looking for an owners manual for a Redfield 6x20x50 Illuminator scope
Contact Leupold, they purchased Redfield.
Here's the info from Redfield's website, hope this helps, Mark the Gunsmith:
When Leupold purchased Redfield in April, 2008, Leupold did not assume the Redfield warranty. Because many Redfield customers have contacted Leupold with regard to the former Redfield warranty, Leupold is making this information available to Redfield optics owners.
At this time, three Redfield repair facilities are available should your Redfield product require service: Parson's Scope Service(513-867-0820), ABO USA Inc (305-859-2010) and Iron Sight Inc. (918-445-2001). The contacts provided are for information purposes only, as these companies are not affiliated with Leupold & Stevens. Please contact them for all information regarding repair, service, and associated charges.
As a courtesy we are now offering 20% off the price of a new Leupold scope, up to $100, in trade for any defective Redfield scope. If you would like to take us up on that offer you may call us at 1-800-LEUPOLD.
Jan 02, 2010 | Redfield Optics
Screw missing in ring that adjust varible power - this screw is a knob that sticks up so you can turn it. i need to find this screw
Here's the info I found on Redfield's website:
Warranty InformationWhen Leupold purchased Redfield in April, 2008, Leupold did not assume the Redfield warranty. Because many Redfield customers have contacted Leupold with regard to the former Redfield warranty, Leupold is making this information available to Redfield optics owners.
Redfield scope eye piece seal came out
Mike, you need to send in your redfield scope back to the manufacture to re-fill the nitrogen in your scope.
Dec 16, 2009 | Optics
I NEED TO IDENTIFY A SCOPE.IT IS A REDFIELD WITH OVAL EYEPIECE AND ROUND FRONT.IT HAS A DIAL ON TOP THAT SAYS UP WITH AN ARROW.IT IS 12.75 INCHES LONG.ALSO HAS A DIAL ON EYEPIECE END THAT GOES FROM 3 TO...
The best guess I can make using my books going back to 1970. Cant be sure of the dates they started, but about 1980 Redfield made what they called, Widefield low profile scopes. They made 7 of these Widefield scopes, 3 Variable power wide view and 2 they called Accu-trac Varable these 2 are in 2x-7x power and 3x-9x power the Accu-trac scope is the one you have I believe.
Nov 16, 2009 | Optics
I have a redfield 3x9 rifle scope and looking for tips on sightin
Yes thats about all there is to it, adjust in small steps and tap on the barrel of the scope with a screw driver handle (light taps) after each adjustment before firing the gun.
Nov 14, 2009 | Redfield See Thru Rifle Scope Mount Base...
Jan 17, 2009 | Redfield See Thru Rifle Scope Mount Base...
Sep 18, 2008 | Redfield Ring and Base Sets for Knight...
Optics Logo
207 people viewed this question
Top Redfield Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Redfield Optic Expert? Answer questions, earn points and help others
