Does it have a antenna hidden?
SOURCE: better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is
really bad (such as in a valley) the antenna would just amplify the
noise as well. Look for web based radio in this case or if you have
cable there are stations on it.
Jeff
SOURCE: AM radio reception
You are correct William, reception is not what it used to be for many reasons. Some corporate owners and local owners have spent much more maintaining FM facilities, and many have neglected the AM's. A good part of the AM signal is via the ground radials beneath each AM tower. In time these radials deteriorate, and with it the signal. Years ago stations licensed as daytime only shut down at night. Quite a few are now allowed to stay on with greatly reduced power, adding to the noise floor at night. You also have more AM licensees now than in the 60's. Unfortunately many of the really knowledgeable AM RF engineers have retired, or are close to doing so. AM directionals require a very experienced engineer. In addition we have many Part 15 radiators, that are devices that radiate a low level RF signal. Every home is full of them, thus more interference. We have power distribution systems that generate huge amounts of noise across the band too. Then there is the issue of manufacturers who have spent more on the FM receiver side of a radio as more migrated to FM. In the 60's, very few were FM listeners. Gone is sensitivity, selectivity and frequency response in the newer AM radios. There are a few exceptions, the CC Crane, and RCA SuperRadio, both sound good with great performance. By the way, the RCA WAS the GE SuperRadio. I also like to pick up some of the vintage radios on EBay and other sites, plus occasionally at yard sales. Unless you are in the country and don't have a house full of gadgets, DX listening can be difficult, but not impossible. Best of luck, [email protected]
SOURCE: poor radio reception
could be or the station you have on.in between towers you will get static.
SOURCE: antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
SOURCE: 2003 towncar radio reception and trunk release
where is the antenna wire located on the 2003 Lincon Town Car?
