Lands Phones Logo
Lynda Lovett Posted on Jun 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Uniden xdect 7055 is not working since NBN was connected. Is it compatible with NBN?
Bill Boyd
Level 3:
Top Expert:
  • Uniden Master 53,816 Answers
  • Posted on Jun 28, 2018
Bill Boyd
Uniden Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11926142
Points
172802
I have a uniden detc 6.0 system and it works with NBN
however you have to have the base unit connected directly into the modem and the land line connected into a different port in the modem
call your service provider and get a diagram of connecting items to the NBN modem
5 Related Answers
Anonymous
  • Posted on Jan 09, 2010
SOURCE: How to set date and time for uniden model XDECT
you have to do it from the hand set, go into menu, using the arrows scroll down to date and time , use the arrows to select date , then hit select do the same for the time, then when the am option flashes use arrows then select , then its done , hope this helps
Pardelope
  • 12 Answers
  • Posted on Mar 30, 2010
SOURCE: recently bought uniden xdect 7055 plus two
The manual does not make it clear that you have to set the day/date/time option on the handpiece - not on the base unit (which you would think was the logical place).
The base unit has only three options under its menu (see page 9 of the Owner's Manual).
See pages 9 and 10 of the Owner's Manual.
Anonymous
  • Posted on Jun 23, 2010
SOURCE: Setting date & Time on XDECT 7055
I have the same problem. The up and down keys just adjust the volume of the phone. I can't change the day and time. Help.
Anonymous
  • Posted on Jan 16, 2011
SOURCE: Uniden XDECT 7055 hand set problem
Hope this is solved for you. If not, I found the connection for the battery a little temperamental and had to play with it a bit before the connection worked properly
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Apr 12, 2011
SOURCE: is there any way of
Hello
Once messages are deleted on this cordless model Uniden phone they are gone for good, you can't retrieve them. I get asked this question allot about many different makes and modes of phones, none that i know of allow the message to be recovered from memory once it is deleted. Sorry
HOW do l set up answering machine message on Uniden XDECT 8315 home phone
The Uniden XDECT 8315 does not have an answering machine. It will check your voice mail. Setting that greeting depends on your telephone service provider. Check your provider's voice mail FAQ.
To have your XDECT 8315 get your voive mail messages, press Message and then select Voice Mail. Then follow the prompts to enter your voice mail access number. Alternatively, you can press Menu > Global Menu Settings > Edit Voice Mail. See pages 17 and 32 of the manual. (See the link below.)
The manual for the XDECT 8315 is available on the product page: https://uniden.com.au/product/xdect-8315-1/ . The current link to the manual is https://uniden.com.au/wp-content/uploads/2017/06/XDECT_83151_OM.pdf .
If you do not have voice mail from your telephone company, you can add a stand-alone answering machine. Just make sure to connect the answering machine to the telephone jack. Then connect the answering machine RJ-11 out to the telephone's RJ-11 jack on the base.
I hope this helps.
Will my uniden xdect6135btu +2 be compatible with the nbn
call uniden but it should be
you have to run the base station cable through the nbn modem for it to work
Is my older uniden dect 1635 +3 phone with only 2 wire coms cable compatible to nbn.
the nbn optic fiber comes to the house and then through a converter back to hard line to the phone socket to use with phones
I cannot see why it will not work
best if you talk with your service provider that is installing the nbn to the house
How do I setup a Uniden Dect 5.8Ghz 8155+2 phone
Uniden XDECT 8155 + 2 Questions & Answers ...
www.productreview.com.au > ... > Uniden > Uniden XDECT 81xx Series
Uniden XDECT 8155 + 2: 25 questions and 38 answers on Australia's largest opinion ...and select Handset Setup or Base Setup. ... If you have a 2.4 ghz or 5.8 ghz modelphone use web address below. .... Uniden Premium DECT 31xx Series.
Why answering service will not take incoming messages when auto answering serviceis turned on
https://www.spark.co.nz/content/dam/telecomcms/other/SSE35_owners_manual.pdf
Before assuming a malfunction in the phone, I would ask you to be sure that the "what message does your phone give to prompt the caller to leave a message" is defined and appropriate. One might do this by calling that phone from another in addition to following the instructions found in the manual regarding that message.
How do i set my time on my cordless phone uniden xdect extended digital 7055
Follow the instructions on page 10 of this manual: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_7055_OM.pdf
Also, in the future please do not post your question as a "solution" to someone else's question.
14helpful
5answers
Recently bought uniden xdect 7055 plus two cordless & i have spent 2 hours trying to get to work but no such luck - seem i have to register my ID with telstra before they will connect me to my telstra...
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
