Try this
search --operators manual for ( you put in make and model) mobility scooter
if there is one available in pdf version , download it
you could go to a shop that specializes in mobility scooters and other equipment for the disabled as many have loan scooters and have a repair facility especially for scooters
SOURCE: sudden stops
Sounds like the brake. Ohm chech the brake (it is attached to the end of the motor). It should be around 35 ohms
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
SOURCE: NEED A REPAIRMAN FOR A 3 WHEEL BATTERY OPERATED SCOOTER IN FLORID
well it most likely the the 5k ohm potenteitometer is bad this is a common ptoblem with pride scooters if you have a screwdriver and can take it apart you can order the part online and it comes with the wire tail on it so it just plugs into the controller board the part costs about 68 dollars from pride depending on what model you have, email me and i could probably walk you through it
