Pedals are NOT pressed on to crank arms.
The PEDAL is *screwed* onto the CRANK ARM (left pedal - reverse thread). The CRANK ARM is *pressed* onto the square, tapered CRANK SPINDLE with a bolt or nut. To remove a crank arm that is tightly mounted to the spindle requires a crank arm extractor, which a bike shop would have, or which can be purchased online.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Testimonial: "these pedals are and yes arm is pressed onto spindle so don't say they are'nt.i'll take a pic...its a weird set up."
SOURCE: windshield wiper arm
These are a tight fit...Spray a little penetrating lubricant onto it and let it sit for about 20 minutes. You will notice there are splines that match up from the drive unit to the base of the wiper arm...sometimes these can get a little corroded and becasue of the relative surface area it makes them a real pain to get off. You may need to just pry against it gently with a flat head scredriver after you spray on the lubricant. Pray at it from all different sides of the base so that it doesn't bind up and get crooked.
Hope this helps! Good Luck!
SOURCE: I am trying to remove the crank form a bicycle
you just need a bicycle crank remover they are cheap. but if you don't want the old one. just get a can of wd40 and spray leave to soak in then acquire two screwdrivers and put them round crank arm and knock them both with a hammer at the same time. (you may need two people) then should come off .
SOURCE: Need to remove the wiper arm from my '04 Chevy Cavalier
its slightly pressed on your going to have to pry it up a little or tap on its side and pull on the arm up with your other hand at the same time
SOURCE: removal of broken rear wiper arm. removed nut but
After removing the nut turn the arm up and wiggle it back and forth while pulling it will come off.
Testimonial: "Thank you for the advice. You saved me labor cost at the dealer and waiting around for the repair."
SOURCE: I can't remove the pedals - I want to remove these
Be advised the left pedal is left-threaded. Get yourself a nice Park brand pedal wrench.
What fixing nut?
How to:
http://www.parktool.com/repair/readhowto.asp?id=83
