Question about Golf
Charger is set for 48 volts (golf cart)when turned on the fault light comes on but it shows charging. Batteries test good, never seem to completely charge.
Posted by Boyd Miller on
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
Posted on Nov 27, 2008
Anonymous
SOURCE: 48 VOLT GOLF CART ''BATTERIES'' HELP !!! CURIOUS
Sams club $77 each
Posted on Jul 24, 2009
Anonymous
  • 4 Answers
SOURCE: charger remains on charged status. will not switch
bang the battery until you get it pregnant ... then wait until a new battery comes out of da dirtbike's *****
Posted on Aug 14, 2009
Anonymous
SOURCE: UPS has a fault. no power coming out back
change the battery and try
Posted on Sep 05, 2009
Repair Ahjoshe
  • 885 Answers
SOURCE: I have a Makita with 2 PA14 batteries and a
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Posted on Aug 19, 2010
My cart has 6 8volt batteries that are dead my manual shows 4 12 volt batteries should I replace the 6 8 volt with 4 12 volt batteries
make sure that they are in fact 8 volt batteries
You can replace them with 6 by 12 volt batteries as the end voltage (48 volts ) is the same
Mar 22, 2016 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Charger just workrd at my neighbors, doesn't even make a sound whwn i plug it into my cart. why does it not take a charge?
Measure your total battery voltage. That is measured across the main positive cable and the main negative cable. If you have a 48 volt golf cart and an automatic charger, any pack voltage under 42 volts will not turn the charger on. Your only recourse then would be to charge one battery at a time until you get 42 or higher.
Sep 07, 2015 | Golf
Charger works but cant get it to charge when plugged into my cart 48 volt
This can be one of several problems. Make sure charger works on another cart first. If it does then check total voltage of your cart, has to be at least 42 volts before charger will turn on. If you plug in the charger and it does not turn on then listen for a small click from inside the charger. That would be the relay and if it operates then your voltage is ok and you have something else wrong. If you don't hear the click then check the small gray wire at charger receptacle. It sometimes breaks just inside the receptacle, Without this sense lead, charger will never turn on. If all batteries, wiring, sense lead, fuse in the sense lead are ok, then it might be the OBC (on-board computer).
May 13, 2015 | Golf Cart Parts & Accessories Energy...
How do you check output voltage from generator to battery in an club car golf cart
if you look at the charger plug there is a small switch it can either be held down with the cover off or with it on. It should read you between 48 and 50 volts DC with that switch in that switch will keep you from charging the batteries if it is faulty. These chargers are really rather simple and golf cart King has the motherboards cheaper than anywhere else that you can buy them. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Oct 31, 2014 | Golf
My 2000 Yamaha golf cart has 6-4cell 8 volt batteries. I did not leave the cart plugged in during the winter months. When I attempted to charge yesterday, the charger lights sequenced but stayed on...
Yes to both questions. the charger must sense 41.5 volts to activate the relay inside the charger. Being a repair shop, I have a charger that is rigged to charge even DEAD batteries. I do not recommend this for the novice. A charger set on 12 volts will bring the batteries back up to 8.2-8.6 volts. A cheap trickle charger may not put out enough to charge a battery of this size. Remember that they are used to MAINTAIN a charge. Connect the Voltmeter and watch for voltage rise. If it rises to 8.1 or above, it is charging. Trojan battery company recommends charging at least once a month.
Apr 06, 2010 | 2000 Ford Focus
Club car golf cart will only travel 3 ft. then cuts off.
See if the motor is bad. If the motor is getting really old the bearings in it may be getting to where they do not turn so easily anymore. On some electric golf carts there is a pressure switch under the seat that if you are not sitting in the cart it will stop the motor for safety reasons. If this switch goes bad then the cart does not know if you are sitting there or not. We used to test these switches by jumping the wires of the switch together to fool the cart into thinking that we were always sitting on the thing. It is a good way to test the switch but not a great way to keep it that way, that switch is there for a reason. If it is bad then get a replacement.
*NOTE: Not all carts have this switch, check with the manufacturer.
Nov 20, 2008 | Golf
Golf Logo
234 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
