Question about Kenmore Refrigerators
I have a 2014 Kenmore Elite Refrigerator and it just stopped cooling. Ideas??
Posted by Joe Strickland on
ray gallant
    Top Expert:
  • Kenmore Master
  • 71,004 Answers
Loss of freon usually is to blame
Posted on Nov 16, 2020
5 Related Answers
22yooper
James Helmer
  • 828 Answers
SOURCE: KENMORE ELITE REFRIGERATOR MODLE #106.53606201
Compressor is cycling on the overload protector. If refrigerator is over five years old the warranty may be expired. I which case I never recommend replacing the compressor if the customer is to bear the full expense.
Posted on Jul 05, 2008
Charles Caldwell
  • 66 Answers
SOURCE: refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Posted on Nov 16, 2008
Anonymous
SOURCE: Kenmore Elite Refrigerator 59676264700 loud clicking noises
check for bad relay
Posted on Jul 29, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Posted on Nov 01, 2009
Testimonial: "That's what my fridge is doing? Thanks for the help."
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Posted on Apr 06, 2010
What is the lifespan of a Kenmore Elite Model 795?
Free Kenmore Refrigerator User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Kenmore > Kitchen Appliance Kenmore Products 1 - 50 of 357 - Kenmore Refrigerator User Manual.
Jul 19, 2015 | Kenmore Refrigerators
I have a Kenmore Elite bottom freezer refrig. The freezer isnt getting cold enough to make ice. Its only getting to be about 30 degrees. Any ideas what the prob is?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 02, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My freezer area works fine, but the fridge stops and starts working continually does anyone please have a solution
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The refrigerator is not working
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jul 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite won't quit dinging
kitchenaid refrigerator, model ksRa25CN5500 stopped cooling
May 11, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite 106.54619300 Ice maker just stopped working
sounds like the moter is burnt out and you need to replace ice maker try ebay
Apr 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
109 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
