Washing Machines Logo
m
menino fernandes Posted on Jun 27, 2018
My washing machine model ASW-70ST water flows from inlet even though the machine is off
Sanyo automatic washing machine model ASW-70ST
2helpful
3answers
SANYO ASW-40AP washing machine keeps filling with water until it overflows.
water level sensor --switch -inlet valve failure ----the machine wont advance till water is at level requested so since it doesn't stop filling it wont cycle to wash -----------https://www.manua.ls/sanyo/asw-40ap/manual
What is the maximum load of Sanyo ASW-70ST top load washing machine please?
There seems to be nothing on the ASW-70, only the 85 and the 100. Normal advice is having the drum no more than half full of dry clothes for the water level in the drum. The least clothes to the most water gives the best agitation and cleaning.
https://www.manualslib.com/manual/665848/Sanyo-Asw-A100ht.html#manual
Sanyo asw 70st washing machine makes lot of nose while spinning
Can any one provide me the Instruction manual for Sanyo #ASW-70ST?
Hello sir This part for sanyo washing machine model ASW-F91AP. Can you advice me how to change bearing .... thank you
1.while it was working it has high temprther with very hot water??
2.and now machine has stoping sotting tast only gining mathin sound?
3helpful
Would you have a user manaual for a Sanyo ASW-F6OAT washing machine? [email protected]
http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
SANYO Owner ManualsTo find an Owner Manual for a SANYO product, enter the model # of the product below.
Please Note: We are in the process of upgrading the Owner Manual search to also include discontinued product documents. Please check back in a week or two if you need an Owner Manual for an older SANYO Product.
Model # ASW-F6OAT
Search Results
Sorry, could not find any documents that match your search criteria
My sanyo washing machine does not fill in water, its director drain out. model asw 40sit.
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Top Washing Machines Experts
john h
