Question about Golf
Harley golf cart no power in forward but great in reverse
Posted by Dan Wann on
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: electric golf cart, mash the pedal won't move
you have a broken belt .
Posted on Jun 03, 2009
shocktroop40
John DeCosta
  • 155 Answers
SOURCE: ez-go golf cart press accelerator pedal and nothing happens
The first thing I would do is lift the seat and check the battery connections. Those batteries are notorious for corrosion at the terminals. Make sure every connection is clean and solid, as in no loose, corroded or frayed battery cables. Next, if the batteries check out, toggle the run/tow switch, also under the seat to make sure it is fully engaged into the run position, and finally check the forward/reverse lever to make sure the connections are clean and tight.
Posted on Aug 03, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: Club Cart Golf Cart Reverse only
You don't have it connected right. The DC motor is 'polarity reversed' to change direction. That's what the controller does is reverse the polarity to the motor to change direction. If the motor is still working in reverse, then the controller is 'probably' okay. Recheck the connections you made.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 03, 2009
Ronald Prier
  • 101 Answers
SOURCE: need manual with the schematics for the wiring of
Need to know what year the club car is. No drawings are in the owner's manual and there are no free service manuals available.
But all is not lost, try buggiesunlimited website for downloadable wiring diagrams. If you still have problems I can maybe help lead you through some trouble shooting steps. email is [email protected]
Posted on Nov 08, 2009
Anonymous
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
Harley 78 golf cart runs great in reverse but not in forward
You posted this yesterday? If it is electric, you need to clean the contacts behind the accelerator pedal. If it is a gas model, you need to get it serviced.
Jun 27, 2018 | Cars & Trucks
Need new or used forward reverse switch for gas Harley Davidson golf cart
I would check with vintagegolfcarts website, they all kinds of hard to find parts.
May 26, 2017 | Harley Davidson Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
MY 1993 CLUB CAR GOLF CART WILL NOT MOVE, I HEARD A LOUD POP WHEN I WENT FROM FORWARD TO REVERSE/ANY SUGGESTIONS?
check to see if there is a circuit breaker on the wire path from your batteries. Could have blown the motor but You would see some smoke more than likely, and smell it burning. What you described with the popping sounds like an electrical short where the wires just burned up but again you'd smell it and maybe see smoke. The switch may be bad also check it with a meter to see it its making contact and see if voltage is coming up to and exiting the switch.
Aug 06, 2013 | Dual Club Car Lester Power Drive Charger...
What is the proper way to stat a gas 3 wheel Harley golf cart?
This is pretty normal if this is an old AMF cart...just have to make sure that your battery is is top shape
Mar 09, 2008 | Harley Davidson Road Tech HA90 MP3 Player
Golf Logo
727 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
