Question about Samsung Heating & Cooling
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
SOURCE: samsung hlr4266wx dlp tv shuts off
This tv usually if detects a fault will display via leds a error flash code. Refer to Owners manual for What the codes are for. If you go to Samsung Website Copy and paste link for manual.
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=televisions&group_cd=&type=televisions&type_cd=02010000&subtype=dlptv&subtype_cd=02010300&model_nm=HLR4266W&dType=D&vType=R&mType=&model_cd=&menu=download&prd_ia_cd=02010300&acc_ia_fl=N&disp_nm=HL-R4266W
Problem may be lamp is failing or ballast which operates lamp may be Bad. Could also be Temperature fault from Inoperable fan or Color wheel. Bulb of course is first choice of possible problem followed by color wheel then ballast. Color wheels usually will start making bearing noise when they start to fail. Hope this helps.
Posted on Jan 14, 2008
SOURCE: Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Posted on May 31, 2008
SOURCE: The electric radiator cooling fan will not turn off
As long as the fan eventually shuts off this isn't a problem,the fan will continue to run for a bit after the car is turned off,once it reaches a set temprature it will turn off.
Posted on May 02, 2009
SOURCE: cooling fans dont engage! 1998 oldsmobile silhouette!
Your Problem Can VERY WELL BE with the Temp Sensor, As It Is the First in This Electrucal Circut . it Waits for 210-230 Degree Engine temp and Gives that Sygnal to the ECM then ECM Grounds out the Cooling FAN RELAY To Turn ON the FANS and the Temp Sensor is Usualy THE #1 Culpret Closley in front of the RELAY.
There are 2 Sensors On this Vehicle The One You Replaced and One Located At Trans Side of
Engine Closer to Front of Vehicle At the Head ,Thereis a 2 wire Plug On it and This Sensor Goes to the ECT witch CONTROLS COOLING FAN RELAY. Hope this Helps and if you Need A Diagram For this It Must be Emailed as FixYa Does NOT Support Large Picture Files. My Email Add. Is MY
Screen Name Here on FixYa @aol.com
Posted on Jun 15, 2009
Jun 07, 2016 | Intertherm Heating & Cooling
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
May 29, 2012 | Heating & Cooling
Sep 10, 2017 | Heating & Cooling
Jun 17, 2010 | Heating & Cooling
Jun 04, 2010 | 1992 Pontiac Bonneville
Oct 04, 2009 | Heating & Cooling
Apr 10, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Apr 20, 2008 | Roper REX4634KQ Electric Dryer
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
374 people viewed this question
Sorry, this a slide in electric range
Has this always been this way?
Just noticed it this morning. It has now randomly stopped after hours of running.
