Question about Laser Office Equipment & Supplies
How to pen left side of Laser jet 1020 printer
Posted by jclift on
5 Related Answers
Anonymous
SOURCE: hp laser jet 1020
My friend had the same problem. A small sliver of paper was blocking one of the contacts where the cartridge connects with the printer. Removed it and voila!
Posted on Dec 10, 2007
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Printer Laser jet 1020
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00385556&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
Posted on Dec 13, 2007
Anonymous
SOURCE: driver hp laser jet 1020
hp driver 1020 downlord
Posted on Nov 05, 2008
niquose
Niqui Itliong
  • 198 Answers
SOURCE: how i print a watermark picture in hp 1020 printer
To change the default settings for all future print jobs in Windows XP
1. In the Windows task bar, click Start, select Settings, and click Printers and Faxes.
2. Right-click the HP LaserJet 1020 printer icon.
3. Click Properties, or click Printing Preferences.
4. Change the settings, and click OK.
5. On the Effects tab, select the watermark you want to use.
NOTE Not all printer features are available from all drivers or operating systems. See the printer
properties (driver) online Help for information about availability of features for that driver.
Posted on Jun 23, 2009
AldRezaine
Aldrine Manalo
  • 995 Answers
SOURCE: how to install hp laser jet 1020 printer at
How to Install a Printer for a Computer Level of difficulty: Easy
Having a printer is very essential when it comes to printing documents whether a computer is for personal home use or in the office. You can also use high-end printers to develop quality pictures. The printer that you would install should be appropriate to the hardware of the computer. There are printers using the parallel port and some prototypes connected through the Universal Service Bus (USB) port. In order to install a printer onto a computer, you should first check the BIOS settings if the parallel port is configured appropriately.
Materials Needed: - Printer
- computer with Enhanced Parallel Port (EPP) or Extended Capabilities Port (ECP)
- printer installation CD
- Internet connection (optional) Step 1 Turn on the computer. Wait for the computer to completely load the OS. Step 2 Attach the printer cable to the corresponding parallel port. After you securely connect the printer to the computer, turn on the printer. Windows will automatically detect the new printer and would prompt you to install the required drivers. Some printers may not be detected automatically by the computer. To manually detect the printer, click the “Printers and Faxes” available on the “Start” Menu. Double click the “Add Printer” icon to launch the Add Printer wizard. If the computer still did not detect the attached printer, unplug and adjust the connection of the printer to the computer. Step 3 The wizard would ask you to choose between a Local Printer and a Network Printer. The computer searches for the connected printer after you select the type of printer. Step 4 The computer prompts you to install the needed driver. The printer usually comes with an installation CD which contains the drivers of the printer. Insert the installation CD on the CD tray. The computer automatically detects the driver files on the CD. Step 5 You need to manually detect the driver required for the installation just in case the driver is not detected. Select from the predefined list of driver software depending on the manufacturer and the model of the printer. Step 6 You may now proceed to perform a Windows update if you still cannot find the driver for your printer. You need to connect to the Internet in order to gather components from the online Windows product support. Step 7 The computer finalizes the installation procedure after the driver is successfully installed. A notification would appear informing you that you have successfully installed the printer. A printer icon would appear on the taskbar. This enables easy access to the configuration and maintenance settings of your printer.
Hope this is very helpful. Don't forget to rate me..:-) Thanks..
Posted on Nov 11, 2009
HP laser jet 2300d
relactoner cartridge first... if the line is still there you need the fuser replaced .. :-)
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Jan 27, 2014 | HP LaserJet 1020 Printer
Hp laser jet 1020 printed blank. toner, scanner ok
laser jet printer oprated with positive or negative charge by charging ruler so please chek it.
Jun 23, 2009 | Office Equipment & Supplies
Window Vista not driving lj1020 printer.
call me on +91 98242 97116 for the instletan of Hp laser jet 1020
Apr 27, 2009 | Microsoft Windows Vista Ultimate Edition
Getting vertical line on the right side of the paper
Sounds like a defective toner cartridge. Try replacing it
Apr 23, 2009 | HP LaserJet 1020 Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Drivers
I loss the drivers of HP LaserJet 1020 printer. I need now. Please help me.
Jul 16, 2008 | HP LaserJet 1020 Printer
Nov 06, 2007 | HP LaserJet 1020 Printer
22 people viewed this question
Top Laser Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Barbat Nae
Barbat Nae
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
