Stephen Lloyd Posted on Jun 24, 2018
Model RX-385. Why does it turn on or turns on with white noise?
Would like kenmore sewing manual model 385 12908
Closest one
Kenmore 385. 12708 Owner's Manual - ManualsLib
https://www.manualslib.com > manual > Kenmore-Ken...
View and Download Kenmore 385. 12708 owner's manual online. Sears Sewing Machine User Manual. KENMORE 385. 12708 sewing machine pdf manual download.
2answers
I need wire colors for CB microphone its a TRC
ALTAI PWR MIC - black/braid= earth, red=RX, white=TX, Yellow=MODASTATIC - blue/braid=earth, black=RX, red=TX, white=MOD, Yellow=Spare
SIRTEL ECHO MIC CBE 2002 - black/braid=earth, blue=TX, white=RX, red=MOD007 POWER MIC - brown/braid=earth, green=RX, white=TX, blue=MODSADELTA EC 980 - braid=earth, green=RX, brn=TX, white=MOD
or braid=earth, black=RX, blue=TX, white=MOD
Scooba 385 - Making Grinding Noises - Video I
there are no parts available for these ( toys ) so called vacuum cleaners. Sorry you wasted your money.
I have a Yamaha RX-385 receiver. I want to increase the number of speakers I can use from the receiver. I am considering buying a speaker selector that says it can connect 4 sets of speakers I can run to...
This speaker selector is standard accessory equipment for home audio equipment -- just follow the instructions with the unit.
The speaker selector unit has circuitry which prevents the amp from being overloaded by connecting too many speakers in parallel to the receiver. The receiver will have to be run at a higher volume level to drive all the additional speakers at the same volume as two sets of speakers, but this will not damage the amp in so doing.
Charlie
I getting noise in yamaha rx-459 please help.
I used to get noise as well. It turned out to be that one of the cables to the speakers was loose. Try tightening the cable connections to the Yamaha and to the speakers.
2helpful
Hi, I have a LXT380/385. I find out haw to turn
I had the same issue here is the quote from the owners manual: To increase/decrease the volume level, press the up or down button during RX or STANDBY mode. With both radios on the same channel hold down the transmit or "PTT" button--this will put the other radio in the RX mode. While holding down this PTT or side button on one radio then you can adjust the volume on the other radio using the up or down arrows. (This is how you do it on RX mode. I'm not sure yet how to enter Standby mode.)
Left channels not working
Check out the left channel amp stages - your issue is there.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
