Question about Mercury Boating
I have a 97 Mercury 75 hp ELPTO motor. I am getting continuous beeps when the key is just in the on position or when to motor is running. Peeing fine and oil tank is full. Ideas?
75 hp mercury outboard motor constant beep alarm
Your engine is not running cool enough. OR SOMETHING IS WRONG with oil injection.
Jun 25, 2018 | Mercury Boating
How much does a 1996 Mercury outboard motor 115 hp weigh
FourStroke 150 hp - Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/75-150-hp/Mercury FourStroke outboard motors are incredibly powerful and efficient, and they feature a wide range of applications. Crafted for less weight and high displacement, they generate abundant torque and immediate power. ... 150 115 90 75. HP / kW‎: ‎150 / 110
Engine type‎: ‎8-valve single overhead cam ...
Dry weight *Lightest model available‎: ‎455 lbs / .
Jun 13, 2018 | Mercury Boating
What year is my 75 hp mercury 4 cylinder serial number 0a986452
Locate the serial number plate by looking on your motor's transom bracket; the plate will have "Mercury Marine" written on the top. The serial number is the top number on the plate. The number directly beneath this is the year it was manufactured.
The year will be determined by the number of cylinders,,,
A 4 cyl. is a 1986 .
75 - 4 Cyl. 1986 ELPTO, ELO A197882 - B249479 = U.S. Serial Numbers A70708 = Canadian serial numbers
Jun 25, 2017 | Mercury Boating
1987 Mercury 75 hp 2 stroke outboard motor clicks when we try to start it
Do you mean it clicks and starter not turning ? if yes then the starter solinoid wires are loose or it needs replacing ! more info needed !
Aug 16, 2014 | Clymer Mercury/mariner 75-275 Hp...
Mercury elpto 90
i HAD THIS ISSUE SERVERAL YEARS AGO , TURNED OUT THAT THE PROP WAS SIZED WRONG,
Jun 27, 2013 | Boating
Wiper speed control for a '97 Mercury Grand Marquis. What causes the wiper to work on high speed only?
Intermittent wiper control stopped working on my 1996 GM last spring. I ended up replacing the wiper motor ($100.00 part). Since I have found it on Amazon for $58 including shipping. It works fine now. Only bad part was all the "stuff" that has to come out (like dead leaves!) to get to the wiper motor. Also make sure you have your wipers in the down position when you replace the motor.
Hutch50
Sep 28, 2009 | 1997 Mercury Grand Marquis
My radiator fan won't turn off on a 97 mercury Tracer.
its probably a stuck relay locate it and replace it with another most likely that will cure it. check under the hood for a relay center.it should be diagrammed on the lid and use 1 from a different position first pull the one for the cooling fan if it stops that should cure it
Jul 18, 2009 | 1997 Mercury Tracer
I have a 65 hp mercury, that doesnt get spark, so it wont start. i just replaced the cdi and the coil, but for some reason the coil is not getting any juice from the battery any ideas on what it could be?
Do you have a Deadman switch? Is the pin in? If yes, disconnect the battery and use an ohmmeter on the ends of the positive and negative main wires but do not cross connect. Loop positive end to positive end with ohmmeter in between to see if you have continuity or not from key. Turn and hold keyswitch to start position. You should have continuity on both POS and NEG respectfully from key to motor connection. Check NEG same way. Then check run position. This way you are checking the ignition side of the keyswitch although your starter does work. Just because the starter works does not mean the ignition is hot.
May 13, 2009 | Boating
Boating Logo
154 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
