Did you ask Gateway? we are not Gateway.ask them?
no symptoms stated, just a CD. (it be dvd not cd, cd to small)
6 years old, can I guess windows 7 you want?
Acer owns Gateway now.
here i am asking there now for you typing
this is how you get the facts.
https://community.acer.com/en/search?adv=&search=install+disks+for++windows+7&title=&author=&cat=all&tags=&discussion_d=1&discussion_question=1&discussion_poll=1&comment_c=1&comment_answer=1&within=1+day&date=
SOURCE: I want to reinstall the software on my gateway
You may have to download support softwares for your gateway system thru here:
SOURCE: system recovery on gateway laptop now no internet
Hi:
If you are on your own home network, you might need to set your connection back up, especially if your network was secure.
If you don't think that is the problem, the other possibility is that your laptop needs drivers installed after the restoration process. If you go to the control panel, and check system info, then device manager, if anything has a yellow exclaimation point or question mark by it,the driver needs installed.
If you don't have a driver or program disk for your laptop, they can be downloaded from the gateway website.
SOURCE: How do I reformat MX6912 gateway laptop without
Download the UBCD and use that.
www.ultimatebootcd.com/download.htm
SOURCE: I have a gateway laptop (no cd, preloaded) Keep
Your missing the file from the nt detect application on the C: drive You will need to obtain a good copy of windows or find an OS that you can work around it with. I would try using Ubuntu as a live session disk and replacing the corrupted nt detection files from a disk or website.
this might help you
http://www.quickonlinetips.com/archives/2005/12/ntldr-is-missing-press-any-key-to-restart/
SOURCE: Hi
can you get into bios or setup and change boot order try that if it don't work give us a holah
