Question about Sylvania Televison & Video
I HAVE A SYLVANIA TABLET DVD COMBO I BOUGHT FROM SOME ONE ON THE BUS AND DONT HAVE PREVIOUS SYNCED ACCOUNT INFO AND ITS STUCK ON FRP LOCK SCREEN WHAT CAN I DO
I ALSO CANT USE GOOGLE KEYBOARD. WHEN I HOLD DOWN @ TO GET THE SETTINGS TO POP UP GOOGLE KEYBOARD IS NOT A OPTION
Posted by michael thomas on
2 Related Answers
kishore_0077
  • 86 Answers
SOURCE: google play wont dowload my apps
Better to reset your tab once...
Posted on Dec 24, 2013
Danny Kuhlmann
  • 1443 Answers
SOURCE: Google lock
Hello,go here for help:
Synchronization issues
Posted on Nov 28, 2015
How to bypass Google verification for zte839 blade vantage
Connect the phone to a Wifi Network (preferably your Home network)
The next screen will ask you for the Google Account
Tap the text field in which the account should be inserted until the Keyboard comes up
Tap and hold the "@" character until a Settings menu pops up
Select Google Keyboard Settings
Tap on the 3 dots in the top part of the screen (or More depending on what Android OS you are running)
Select the Help&Feedback item and select any item in the list that will follow
Bypass Google account Samsung 1
From the Help section, tap on Using Google Keyboard.
Long press to select any text on this page and click on Websearch in the upper right corner
A search field will be shown (delete the text inside the search field)
Type Settings in the search field
Bypass Google account Samsung 2
Scroll down until you find"About Phone" and tap it.
Enter the menu and look for Build Number. Tap 7 times on the Build Number to enable Developer Options
Return to the previous menu and open the Developer Option that just appeared
Allow OEM Unlocking and tap Back two times
Restart the device
Connect it to Wifi again
Notice how you won't be prompted to log in the previous Google Account and instead the phone will ask you to ADD a new Google Account
Add the new account and your phone will be ready to use.
Or call 1-888-524-2670
Sep 17, 2018 | Google Computers & Internet
Tip
How to Reset Parameter RAM (PRAM) - Macs
Resetting Parameter RAM (PRAM)
PRAM stores certain system and device settings in a location that Mac OS X can access quickly. Exactly which settings are stored in the computer's PRAM varies depending on the type of computer as well as the types of devices and drives connected. To reset PRAM:
1. If computer is on, turn it off by choosing Shut Down from Apple menu.
2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in Step 4. Note: If keyboard does not have an Option key, use Alt key instead.
3. Press power button.
4. Immediately press and hold Command-Option-P-R keys.
Important: You must press this key combination before the gray screen appears.
5.Hold down keys until computer restarts, and you hear startup chime a second time.
6.Release keys.
on Mar 01, 2011 | Computers & Internet
I have a new Alcatel one touch, Fierce 2 cell phone. I bought it last week. When I first used it, the phone had a microphone icon in the texting area. Now it's gone. How do I get it back so I can
If you good down the comma button the setting menu for the keyboard should pop up. If it does not it may not have the standard keyboard installed especially since you may have added an emoji keyboard. You can select the manufacturer default from the same menu by going to phone settings then keyboard. The last option would be to go to the Google playstore and download the keyboard put out by google. To do this do a search for google keyboard make sure that google is listed as the developer. Once downloaded and installed choose the keyboard from the settings, input, keyboard menu.
Dec 02, 2014 | Alcatel Cell Phones
Keyboard shortcuts on a HP Black Pavilion 20-b013w All-in-One Desktop ?
Hi Julie--I'm assuming by keyboard shortcuts you mean the way you used to get to safe mode by pressing F8 during bootup. If that's not what you meant, please clarify and I can revise the answer.
The easiest way to get to safe mode in Windows 8 is to move your mouse to the lower right corner of the screen to bring up the charms bar. Click on SETTINGS ---> POWER
The pop-up menu will give you three options, SLEEP, SHUTDOWN and RESTART.
HOLD DOWN THE SHIFT KEY and while continuing to hold it down, click on RESTART and this will immediately restart the computer and boot into ADVANCED STARTUP.
From the menu that appears, select the middle option, ADVANCED
then select SAFE MODE.
Mar 30, 2014 | Computers & Internet
How do I turn off pop off blocker in chrome?
Hi Joditinnj,
Please try this steps and if won't work you may want to visit the link below for some steps to resolve your issue. Hope it helps.
  1. Tap the Chrome menu in the top right hand corner of your browser
  2. Select Settings
  3. Tap Content Settings
  4. Toggle Off the Block Pop-ups option
How to Disable Popup Blockers
May 01, 2013 | Google Chrome
I cant remember my administrator password, is there a way to reset or undo it
Restart your computer, when you see your computer manufacturs logo pop up, start pressing the F8 button on your keyboard. Some options will pop up onn your screen, useing the up and down arrows on your keyboard, scroll down to the option "safemode with networking" and press enter. After a few minutes your login screen should pop up with two admin. accounts, one password protected, one not, click on the open admin account, do not be alarmed by the way everything looks, your in safe mode. From in here, go to control panel/user accounts, select yours and choose the "remove password" option. Your done. Restart your computer, select your account from the login screen - and you will be let in.
May 15, 2012 | Compaq Presario Laptop with AMD Turion 64...
My baby has changed the language on my text input and i cant change it back,, how do i do it?
Xperia X10
To set the phone language:
1. From the Home screen, find and tap Settings > Language & keyboard > Select locale.
2. Select an option.
Note: The chosen phone language is also the writing language, if not selecting a specific writing language.
To set the writing language:
1. From the Home screen, find and tap Settings > Language & keyboard > Default input > Writing languages.
Useful tip:
* To change the keyboard when you're in a field that requires text or numbers, touch and hold the text bar, then tap Input Method and select an option.
* To enter special characters, such as å, just touch and hold the corresponding letter, and select an option.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 08, 2011 | Sony Ericsson XPERIA X10 Cell Phone
How to turn off filter keys on a Eee pc and what
Filter keys was introduced by the windows operating system its function is to filter out quick repeated keystrokes.
To toggle filter keys on and off hold the shift button down for eight seconds until you receive a pop up asking if you wish to turn filter keys on/off. In that pop you you will also be given the option to disable the function all together.
Mar 01, 2011 | ASUS Eee PC 900 Notebook
How do i configure my pop-up blocker
Open up Google Chrome (I'm assuming you mean the pop up blocker for Chrome since you posted under the Google Chrome section). Click on the Customize and Control Google Chrome button (it's a wrench in the very top right). Select Options from the drop-down menu. On the Google Chrome Options window, click on the "Under the Hood" tab. Now select the Content Settings button. Click on Pop-ups in the Content Settings window. Here is where you configure your Pop-up Blocker. I suggest you select "Do not allow any site to show pop-ups (recommended)." If you're attempting to let a specific website or two utilizie pop-ups, click on the Exceptions button. On the Pop-up Exception window, click add, and now type in the website address for the website that you wish to use pop-ups.
Hope this helps!
Dec 15, 2010 | Google Chrome
Compaq keyboard
Try pressing the ALT GR-key instead of the up (shift-key).
Sep 04, 2007 | Compaq 118003-008 Keyboard
Televison & Video Logo
531 people viewed this question
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
