Question about Mercury Boating
I have a 2018 Mercury 4 Stroke. 4 times now, the engine has cut off and won't restart for a while.
Posted by Rod J on
5 Related Answers
Daryl Spindler
  • 6 Answers
SOURCE: my lawnmower engine cuts out
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Posted on Apr 14, 2009
Anonymous
  • 20 Answers
SOURCE: issue with a 2004 40 hp 4 stroke mercury engine,
have you checked to see if there are any blockages
Posted on Jul 31, 2009
Anonymous
SOURCE: Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at http://www.crowleymarine.com/mercury_parts/6995/240.cfm which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
Posted on Nov 12, 2009
thomasnee
  • 677 Answers
SOURCE: 4 stroke 6hp mercury outboard -brand new first
????? Was the dealer using his fuel tank or yours.Might be a blockage or contaminate in the fuel tank.Hope this helps
Posted on Dec 03, 2009
goldbill
william moore
  • 184 Answers
SOURCE: 30 hp 4 stroke carburator problem
Check your "sync n link" of the throttle pick up and the ignition timing.
Posted on Oct 14, 2012
I replaced the fuel pump and all was fine. Next time the primer bulb it wouldn't get hard. fuel shot out of the fuel pump into the engine compartment.
Make sure all of your hose clamps are on securely and there are no cuts, tares, kinks, or pinch points in the line.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/saam_2816e29ba1070532
Nov 24, 2017 | Mercury Boating
Mercury outboard s/n OT603376 Is this a 2 stroke or a 4 stroke motor
Go to MarineParts.com and put in the s/n and they will id the engine hp, stroke and year.
Sep 08, 2017 | Mercury Boating
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
Why won't my mercury marine engine not restart after running for 30 or 40 min.
is it cooling ok ? run on hose and check engine block and exhaust plate cool ! water inlets clear and impellor good condition ? compressions all over 100psi ? carbs clean ?
Jul 23, 2014 | Clymer Mercury/Mariner 75-225 HP 4-Stroke...
Aug 05, 2012 | Seloc Mercury Outboard Engine Repair...
Have an old Home Lite chainsaw not used since before I had it running when I had some woods to cut a long time ago. The chainsaw (over 25 years old) won''t start when I try....not sure if it just needs a...
Replace the fuel filter, fuel lines, primer button (if equipped), and disassemble the carburetor, clean, and re-kit. Jet needles are preset at 1-1/2 turns CCW from stops (lightly). Make sure the spark plug fires a snappy blue spark when pulled through. If nothing, ignition parts prices and availability may justify replacing the saw with a new one. If sparks ok, start the engine and let warm up. Open the throttle and adjust H needle CW till the engine speeds up, but still 4-strokes. Proper setting is when the engine will 4-stroke, but immediately 2-stroke when cutting. Let the engine idle and adjust L CW so that the engine idles fairly well, but allows the engine to 'follow the throttle' Hope this helps!
Apr 17, 2010 | Garden
Boating Logo
76 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
