Fans all work, compressor is very warm to the touch. Vents are clean. Inch away from the wall so air flow should be good. frig is very cold but not freezing.
SOURCE: warm frigerator
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If you don’t know what these are then unplug the machine and let the ice
melt in the freezer overnight with the door open. Then try it the next day, if
is cooling fine then you need to have a service person replace one of the above
items.
if you already checked this and think
it is a different problem then let me know, i will help you figure it out.
Mike
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
SOURCE: Frig warm, Freezer Cold
Hi friend
it is nothing but thermostat(black heat coil) problem please check it
thank u.........
SOURCE: Refigerator is warm, freezer works fine. There is
Your defrost system has failed. The ice buildup prevents the fridge side from cooling properly.
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
