Https://translate.google.com
why it's not ******* to restore facebook
Hindi ko maintindihan ang tanong.
I don't understand the question.
SOURCE: patay sinde
Your concern is that the TV turns itself off. This could probably be due to any of several possibilities:
1. cold solder or loose connection, may maluwag na koneksyon sa loob o mayroong hilaw na hinang. Kailangan lamang itong painitan ng soldering iron upang muling manumbalik ang kinang at tamang pagkakapit. May mga pagkakataon na maaring maluwag din ang ACplug sa outlet;
2. heat induced - may pyesa na nag-iinit at tumitigil sa pag-andar pag mainit na. Kadalas ay mga capacitor, transistor or regulator;
3. low supply of the AC mains - mababa ang kuryente, maaring ito ma-check sa pamamagitan ng isang Voltmeter. Kung mababa nga, maaring gumamit ng voltage regulator kagaya ng sa mga computer;
4. timer - may mga pagkakataon na mayroong timer kaya kusang nag-switch off anf TV makalipas ang takdang oras;
Of course repairs would involve knowledge and familiarity with electronics circuitry and components, use of a DVM and a soldering iron. Should you be uncomfortable performing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: ang printer ko na EPSON LX+300..pag nag print
Here is some great printer solution by Some FIXYA EXPERT. Get any kinds of printer solution from bellow.
akddij16
SOURCE: kumakadyot ang car ko par 1st 2nd 3rd gear.pero
It sounds like you need a general tune up.
The problem would be timing, your ignition should be set to the right timing to avoid that acceleration hiccups.
Check also the spark plug gap.
Hope that helps you out!
thanks for using Fixya!
Kabayan paki rate mo ko at nice comments!
Testimonial: "tnx sir for giving me idea.bout my car problem.professional ka ba? "
SOURCE: hindi ko na alam kung
Nasubukan na niyo gawin ang mga sumusunod:
1) Pumunta sa Website ng facebook o i-type ang www.facebook.com sa internet browser.
2) Sa ilalim ng Password field, may makita ka Forgot your password.
3) Pakipindot ho ito. May lalabas na panibagong web page.
4) Tatlo ang pwedeng pagpipilan para makuha niyo ang password:
A. Email/phone - ilagay yung email or telepono na ginamit niyo sa pag-regiister sa facebook
B. Facebook Username - ilagay yung facebook username ginamit niyo sa pag-register sa facebook.
C. Name and Friend's Name - ilagay yung pangalan mo sa field your name. Sa friends name, ilagay yung pangalan ng kaibigan mo sa Facebook. Pag ito ang napili niyo, ang password mo ay ipapadala sa facebook inbox ng kaibigan mo.
SOURCE: may problema ako sa epson
bakit ganito ung epson t60 ko ayaw lumabas ng black nakaka ilang head clean na ko ganun parin ang dami ko nang nasasayang na papel ganito problem kapag naka ciss? plz help me how to solve this problem...tnx godbless
