Question about Samsung Audio Players & Recorders
How do i Unlock SAMSUNG DVD HT-E330K , it shows 'locked' when the eject button is pressed
Posted by Louis Ntege on
Shepherd Khumalo
    New Friend:
Followed your 4 steps but failing to unlock the tray
Posted on Nov 11, 2018
Terry
  • Samsung Master
  • 11,377 Answers
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Anonymous
  • 253 Answers
SOURCE: how to unlock the eject button on a pioneer avh-p4000dvd
remove ur eject option from menu bar and for tchnician help contact http://tinyurl.com/mtgjzz
Posted on Jun 22, 2009
Anonymous
  • 70 Answers
SOURCE: We have a Samsung Digital
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Posted on Jul 08, 2009
Willard Broughton
  • 252 Answers
SOURCE: My DVD player won't open,
It is out of time and will have to be serviced by a tech
Posted on Aug 05, 2010
Anonymous
SOURCE: my samsung ht c350 wont
Found out how to solve this problem, as it has put a child lock on the device, try holding the Stop button on the remote for five seconds. This resets the device, then turn it back on and it will go through inital setup and then try oepning the tray.
Andy
Posted on Feb 12, 2011
I have Samsung HT-E330k but center and surround speakers don't function but if i go in settings and put test speakers, they play a beep sound.
That shows the unit is switching them off somewhere. Perhaps on different modes or surround settings.
If you have a DVD marked THX that will have testing settings for the system. Then you will be able to found out if a setting on the amp is responsible for the loss of channels.
May 10, 2018 | Samsung Audio Players & Recorders
How can I unlock Samsung HT-H4500R
1) Turn on the player with no disc in the tray.
2) Open then close the tray, wait to see the No-Disc Message
in the top Left Corner.
3) Now press the REPEAT button on the remote, followed by a
five digit code. eg. 57538 if you have a region 2 player.
4) When it works a 2 (your current region) will appear in
the top left corner.
5) Press 9 to make it region less.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all
regions of DVD/BD Disc.
Here is a list of all the region codes:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
Aug 25, 2014 | Samsung Televison & Video
Tray wont eject and it says locked... how to unlock hte330k samsung?
If your hk-e330k tray doesn't open shows looked,Switch on the DVD and press & hold reject button for 5 seconds it will show you UNLOCK then you can that enjoying Home Entertainment System...Thanks for viewing!
Mar 03, 2013 | Samsung DVD-HD960 DVD Player
Unlock samsung HT E 330 K
Hi i am using samsung dvd HT-E330K..I cant watch few dvds on my dvd ..i need the code to unlock my dvd so i can view all the dvds
Feb 23, 2013 | Audio Players & Recorders
How to Unlock a Sony DVD player DVP SR320 which displays "LOCKED" when eject/open button is pressed?
Apr 22, 2012 | Televison & Video
My samsung HT-C350 won't eject. It keeps saying lock when I press eject.
Hello
Your Samsung HT-C350 is paretial locked. You have to unlock it. If you have forgotten the passcode, do these.
There is no no dic inside I thinks. If there is a disc inside, remove it by by anyway opening the device. If there is a disc inside, the player will show its contents and you can confirm it.
Press and hold STOP button on the remote control for 5 seconds or more. All the settigns will revert to Factory Settings.
OK.
Apr 12, 2011 | Samsung Audio Players & Recorders
My samsung ht c350 wont eject, it says lock when i try to eject it
Andy
Jan 14, 2011 | Samsung DVD-C350 DVD Player
I have dvd that stuck in it. Its playing the DVD but it will not eject. when I press the eject on the remote, a lock shows on the monitor. Please help.
I had a T.V that wouldn't allow a video eject if the top panel was locked maybe this is the same. To unlock the panel: Press and hold the VOL down
Oct 04, 2010 | Toshiba 23HLV84 23 in. TV/DVD Combo
We have a Samsung Digital Home Theater System HT-DM150. After some guests were fiddling with the remote, we find that we cannot eject a DVD that was inserted. The DVD plays OK, but when we try to eject,...
Jul 05, 2009 | Samsung Audio Players & Recorders
Display reads OPEN LOCK when I try to open dvd tray.
Jun 26, 2009 | Samsung HT-DS610 System
615 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
