Question about The Computers & Internet
SOURCE: Setting for AP via Router Mikrotik
please connect a one end of the cable named v.35 in the consloe port of router and other end in the modem.load the router through console port through roughter cd...
thank you...
Posted on Jan 05, 2008
SOURCE: dlink 2100 ap
If you default the unit, does it still reboot?
If so, it looks like the unit is faultly.
If not, you might have a IP conflict, or channel problem. Check the two units are on the same channel, but have differant IP address.
Posted on May 09, 2008
SOURCE: I have 2 3COM 3CRWE454G75 -> AP, it does work in AP repeater mode
find the ip address problem or the firewall of there or proxy servr is there and re-configure it then you get the it and check the region if not same that also creating problem sir,
Posted on Mar 06, 2009
SOURCE: AP does not work in Repeating Mode?
check your wi fi is enabled on ap settigns also che k broad cast ssid is enabled on it.
Posted on Apr 27, 2009
SOURCE: WRE54G To Connect With The WRT54G in repeater mode
hi..you only need to reset your router..their is a small hole at the back and just push a little pin to make a resets...Thanks..Good Luck..^_^
Posted on May 12, 2009
Jun 21, 2018 | Internet Computers & Internet
Oct 29, 2011 | Zyxel P660HW-D1 Router
- Make sure you are directly connected to the unit.
- Do not have a switch or router in between and do not connect wirelessly.
- Make sure your power injector/adapter is on, power is going to the unit, and the "network" side is going to your computer.
- Make sure your computer is set to a static IP address of 192.168.1.10.
- Type in 192.168.1.1 using Internet Explorer.
The default IP address is 192.168.1.1. This IP address is typically in conflict with many routers out in the market. You will need to change the IP address manually to an IP address that is different but part of the same network. This means if your router IP address is 192.168.1.1, you should change the device to 192.168.1.2, for example. We recommend you change the IP address before other settings. You change your IP address in the "LAN" section in the GUI.
How do I reset the device?Locate the reset button next to the CAT5 (RJ45) connection. Press and hold the reset button for 10 seconds and then let go. You should see your 10/100 LAN connection at your computer go away and then come back. That will confirm a reset has occurred. The unit settings should all be back to default including its IP address of 192.168.1.1.
How do I set up AP WDS Repeater?
Click here for instructions.
How do I set up the device under Apple MAC OS X environment?
I cannot connect or maintain a log in to the device.We recommend using internet explorer with at least IE7 or higher. Make sure you have latest version of Java script.
What distance in kilometers (km) should I set the device to?Default is 1km. If you are setting up long distance point to point links, the time it takes the radio wave to get there needs to be considered for proper handshaking (ACK response). This window should be accurate within 5 kilometers. In other words if you have a 5 kilometer link, ideally you should set it to 5km, but a setting of 1km to 10km should keep you in an acceptable window. For short distances, keep this to 1km.
What is a point-to-point link setup?One unit would need to be in AP mode while the other in CB mode. The AP should be connected directly to the routers LAN port, and the other will be in Client Bridge Mode linking back to the AP. The Client side will then provide a WIRED connection for users of the remote location. You can choose to connect this wired connection to just one PC, or to a switch, hub, or another wireless access point for multiple users at the remote location. What is a Client Bridge (CB) Mode?A client connects to an access point. Your laptop is a client. A bridge is something that connects two "wired" networks together. A client bridge therefore is a radio that wirelessly bridges two networks. The Ethernet port of the 2610 in CB mode provides the wired connection to the remote location. This Ethernet port can directly connect to a single PC, a hub, a switch, or another router.
What is considered a "good" signal?The signal meter is not available in AP mode. In CB mode, under connection status, a signal of -74dbm or better is a good signal. It's important to understand which direction numerically is a better signal. Dbm's are referenced to 1 milliwatt. 1mW = 0dbm. A stronger signal would be a positive number and a weak signal would be a very negative number. For example, a -50dbm signal is stronger signal than -92dbm. What is spanning tree protocol?When there are several possible paths a packet can route to (redundant links for increased reliability for example), a loop can occur (jamming up the network). It is used to prevent these loops.
What is the default gateway?The default gateway is your router's IP address. The default gateway information is not required, but is recommended.What is the default user name and password to log into this device?Log in name is "admin" and password is "admin" by default.
What is WDS Mode?Stands for Wireless Distribution System. Allows access points to link together and provide repeating. Note however, this repeating comes at a cost of reduced bandwidth. Bandwidth will be reduced by 30-40%, and it is recommended that NO multiple repeating hops be done for this reason. Which antenna connector is the primary antenna?The one closer to the power jack.Jan 06, 2011 | EnGenius Technologies ECB3500 802.11g High...
Mar 11, 2010 | Levelone WAP-0005 (DHWAP0005) 802.11b/g...
Apr 27, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Mar 21, 2009 | Computers & Internet
Sep 10, 2008 | Linksys Wireless-G WRT54G Router
Jun 09, 2008 | SMC EZ Connect g SMCWEBT-G
Nov 12, 2007 | Computers & Internet
1,356 people viewed this question
