My Haier pulsating portable washer sprays water when I turn on the taps. It sprays from where the hose is connected to the metal ring that you screw onto the water inlet on the machine. Both hoses do this. All 4 rings are wobbly, they shake back and forth and spin round and round. All the rings have rubber gaskets in them.
SOURCE: metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
SOURCE: Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
SOURCE: Haier XQB55-10 : water leakage from inlet hose jointer
Inside the connector is a flat washer and a mesh filter. one side of the mesh filter has a strip/bar across it, this filter goes into the base of the connector with the strip/bar upwards, make sure it is seated in the connector properly.
Then fit the flat washer ensuring that it is clean/undamaged and lying flat at the base of the connector, the mesh filter strip/bar has at either end a small lip, the washer goes underneath the two lips, if it is placed on top of these lips it leaks!
99% positive on this, if not buy another hose!
SOURCE: Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
