Sure!!!!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: I have Carrier 58 MVP 120 (Heat pump/gas) variable
The most likely cuase is bad connection at the board and or motor. Just pull them off and reconnect them and wiggle em.
SOURCE: carrier mvp 58 what size evaporator fits on top
20' case will match the out side dimension of the furnace
SOURCE: Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
