Question about Golf
What size tires do I need for A Yamaha sun classic I think it’s a 93
Posted by Joe pedro on
Andrew Taylor
    Top Expert:
  • 33,363 Answers
3 Related Answers
Anonymous
  • 292 Answers
SOURCE: Removing Yamaha rear tire (1100 Classic)
do you mean remove the wheel? tires are best left to a shop to do as they have the machine. drive shaft yes? undo all bolts thru frame to final drive casing. slacken wheel nut but do not remove spindle, pull wheel back and out of the frame the drive shaft comes with it, tace out spindle and now lift final drive from wheel, there may be a spacer which might fall out. done deal..
Posted on Mar 21, 2009
Matthew Boulden
  • 440 Answers
SOURCE: need to know the tire size...
Ok, if it is the base model the tire size from the factory is 205/ 70 r15. Otherwise it is 205/70 r14. Obviously the difference is the rim size which you can get by measuring with a tape measure. Measure the rim diameter and if it is 14 across then it is the second one, if it is 15 across it is the first one. The tire shop can also help with this. FYI, the cheapest place I have found for new tires is Walmart.
Posted on Nov 04, 2009
edwar355
edwar355
  • 71 Answers
SOURCE: Do I need to remove my front tire in order to
You don't have to but, I would to avoid scratching it
Posted on Feb 19, 2010
What is the correct tire pressure for 2-riders on a 2004 yamaha v-star classic
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Yamaha despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Tire Pressure
Yamaha Motorcycle Tire Pressure
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 21, 2014 | 2006 Yamaha V Star 1100 Classic
How to change rear tire on 2005 1100 v-star classic
Need Help with Rear Wheel Removal on 1100 Star
2008 Vstar Rear Tire Change
Jun 05, 2014 | 2005 Yamaha V Star 1100 Classic
2005 yamaha v star rear tire change
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Tires Star 1100 Wiki Knowledge Base
Jun 30, 2012 | 2005 Yamaha V Star 1100 Classic
Vstar 650 2005 tire pressure
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha Motorcycle Tire Pressure TirePressure com
Yamaha XVS650 Service Manual
YAMAHA XVS650 Owner Manual
Jun 22, 2012 | 2005 Yamaha V Star Classic 650
Tire pressure vstar yamaha 2003
that all depends on what brand of tire you have on the bike,, check the sidewall of the bike for proper tire inflation , if you can't locate it,, send me the tire size and brand of tire, and I'll try and locate that info for you , just reply to this answer
Sep 07, 2011 | 2005 Yamaha V Star Classic 650
How do you take the rear tire off a 2000 V Star Classic 1100?
Hi, 2000cbr for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Feb 20, 2010 | 2000 Yamaha V Star 1100 Classic
What's the widest rear tire that can be installed on a 2002 vstar 1100 classic without a drive train modification
With out modification to the drive train you can go up one more tire size than stock as lond as you have clearance on both sides of the tire any where around the back of the bike.
Oct 29, 2009 | 2001 Yamaha V Star 1100 Classic
Tyre pressures
Look around the tire and you should find the max inflation pressure for the tire. The pressure info will be smaller than the tire size info but it will be there somewhere.
Okay, that is the max pressure. It is probably 45psi. Try 45 psi and if you want a bit softer ride go to 40 then 35 then 30 until you find the inflation pressure that gives you the desired ride without being squirrely. I think 35psi is where you will settle.
Please rate this answer. Thanks!
Apr 01, 2009 | 1983 Yamaha XJ 400
Feb 26, 2009 | 2001 Yamaha V Star 1100 Classic
Golf Logo
377 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
