Question about Internet Computers & Internet
I have an OptiCover AC1200 WiFi Range Extender. I also have the WPS on my router.
Q1 - on the side I have 3 options AP, Repeater and router - which should I select? Q2 - how long should it take for the LED turns solid Q3 - is it all the LED lights, Just the ones on the bottom of the extender and/or the middle light that show internet power Q4 - once the the LED lights on solid, and press the WPS button on my router, and the top button of the extender, how long should it take to connect? What else do I need to know
Posted by JM Radeztsky on
Carlos L. Glez
    Loyalty:
    Visited the website for 30 consecutive days.
  • Internet Master
  • 419 Answers
Https://www.downloads.netgear.com/files/GDC/EX6110/EX6110_QSG_EN.pdf
Hello, this link you can find all your answers they explein step for step.
Posted on Sep 30, 2018
3 Related Answers
Rishi Roshan Ali
  • 2427 Answers
SOURCE: Plug in Extender, while the
Chances are you need to reset your extender and then connect it back to your routers.. Setup your router and ensure you can connect to it suing your laptop,
Connect your extender to your laptop and connect to the wireless network of your router,
now connect to your extender wireless from your laptop
now once connected to your extender, ping your router ..
once you have a ping you should be set..
Posted on Nov 01, 2010
TechyDrood
Justin
  • 2072 Answers
SOURCE: I have a 2-wire 2701HG-B
Doesn't look like your router/modem supports WPS, here is the manual. http://www.2wire.com/pages/pdfs/2701HG_user_guide.pdf
I would check your Range extender model because some allow for a wired configuration
Here is a How To, to configure the extender via cable and utility http://support.netgear.com/app/answers/detail/a_id/41
Here is a list of Range extender models http://support.netgear.com/app/answers/detail/a_id/34
Posted on Jul 09, 2011
Joseph Wright
  • 1729 Answers
SOURCE: Just installed the OptiCover Range Extender and now my speeds to connected devices is slower that going directly to my WIFI modem. What is wrong?
Did you connect to the new device? It should have a different ID.
Posted on Apr 29, 2018
How do I set up my Wavlink WiFi Range Extender?
Press the WPS button on your host router, then press the WPS button on the extender within 2 minutes.
Wait until the Signal LED changes to solid blue, which indicates that the WPS connection is successful.
It's done and the WI-FI repeater will automatically find the signal.
Enjoy. Both extended networks share the same SSIDs (network names) and passwords as those of your host networks.
I need how to set a password on the wifi AC1200
login to the router main interfacew normally by 192.168.0.1 the user and password are on a sticker on router somewhere and then there will be a tab in interface that will say Wireless the pass word can be changed via there. another alternative is if the router has WPS just press button on rpouter and on device find WPS connect in wifi settings and it will auto connect.
6helpful
3answers
My Netgear WN3000RP Wi-Fi Range Extender is not working since last night . please help
Try unplugging BOTH the repeater and the router, Then, plug the router back in and let it establish a connection. Then, plug the repeater in and let it reestablish the connection.
I have a new DAP-1360 that I want to set up as a repeater. The wizard to get it on my wi-fi network is fast and easy, I join thru site survey and it appears all is good. Then my wireless network stops...
talk to Dlink directly. (no main router stated, model?)
it is just a RANGE extender,
7 different modes
Access Point,
Wireless Client,
Bridge, Bridge with AP, Repeater, WISP Client Router or WISP Repeater
Compatible with 802.11b and 802.11g Devices(no main told) .
repeater mode (1 of 7) is covered in the manual
and wirlessly bridges to the main AP, and extends the range of the wifi to the new zone,(goal?)
( do this here but use Ethernet from main to new AP) vastly better.
page 26 in your manual covers setup for Repeater mode.
did you do that?
step one is the SSID, use a new name here, not same as other AP or other wireless nodes, ok?
step 2, select repeater
I never use WPS so I skip this (its insecure)
pick manual
page 29 find our main router, SSID name, or survey it.
this is very important to marry the new AP to the old router SSID.
my main would be WPA2, id not use any others (security)
then type in the mains , Password, 8 to 32 chars.
its done.
update the firmware in both routers first? be wise that.
I never do this ,all it does is slow down wifi in 2nd zone.
for sure walls present ! in the line of site paths.
I bridge them with ethernet (wired) now both zone go full speed.
I just bought a TP-Link router. I was told to change my IP address because my internet provider's IP is 192.168.2.1 instead of 192.168.1.1. How do I change my IP address?
Log in to router via browser at: 192.168.1.1
At login and password promt enter
login: admin
password: admin
Navigate from left pane: Advanced setup -> LAN
Enter there you'r new ip: 192.168.2.1
Subnet mask: 255.255.255.0
Save
Dwl-2100ap set up propblem
There's quite a bit to know about extending / repeating WIFI signals.
Read about extending a WIFI signal with a Sitecom WL-130 repeater here.
Computers & Internet Logo
Ekse
 Francisco Mauricio...
 Grubhead
Grubhead
